Author Topic: Tranny rebuild done but lots of hassles  (Read 987 times)
Offline Racer57
« on: July 26, 2013 - 05:01:20 PM »
My 70 Cuda 383 with a 23 spline 4 speed had a lot more whine than it should've had and front seal was leaking badly. Pulled it out and took it to a reputable shop to diagnose and repair. Apparently it had sat for long enough of a time that the gears above the oil line had corroded enough to be pitted very bad. Weber and Passon didn't have my all of parts in stock but shop found that Pro-Gear in California said they did. I could either get only the damaged gears for $450 and gamble on bearings or get the complete gearset with everything for $1,280 including overnight shipping and labor. So I went with everything.
1. Gear set comes and its an 18-spline instead of 23.
2. Next day its the correct gear set but no bearings or seals.
3. Next day everything comes, but one bearing is wrong.
4. Next day finally have everything.
Take it out for test and the whine is 75% gone and is level of sound that its suppose to be. Decide that its time to REALLY go through the gears since engine should have enough break in miles to do it finally. Frikkin clutch is slipping after it hits 3,000rpm !!  Check free play and there is 1" of pedal travel.   :stomp: :swear: Gonna take it easy and pull the tranny back out and change clutch later this summer. Time to just enjoy. (for now)
Re: Tranny rebuild done but lots of hassles
« Reply #1 on: July 26, 2013 - 11:40:41 PM »
What clutch system did you go with ?
Offline Racer57
« Reply #2 on: July 27, 2013 - 08:35:39 AM »
Its what was already in the car when I bought it. It had been frame off restored and appears to be the factory replacement 10.5 and looks like new.
« Reply #3 on: July 27, 2013 - 10:03:26 AM »
I stay away from the diaphragm clutches & I never use a 10.5 , the 10.95 bolts on & it just makes sense to increase the surface area & holding power / life as well
Offline Racer57
« Reply #4 on: July 27, 2013 - 10:08:07 AM »
Thanks.
Is there a particular brand that you recommend ?
« Reply #5 on: July 27, 2013 - 10:15:42 AM »
I have been using McLeod , I have no reason to find another vendor , their products & service have been great .
Offline Cuda54
« Reply #6 on: July 27, 2013 - 10:26:40 AM »
I have 1 question how do you do a Frame Off Restoration  on a unibody car?????????  I hear it all of the time never ever figured it out yet. It sound like the guy that puts a chebby engine into a mopar. It just is not right. SORRY! :pullinghair: :stomp: :banghead:
« Last Edit: July 30, 2013 - 11:20:05 AM by Cuda54 »
