Bell housing CORRECT vs what works for my car
Author Topic: Bell housing CORRECT vs what works for my car  (Read 925 times)
Offline Todd Smith
« on: July 28, 2013 - 02:24:42 PM »
Please correct me where I'm wrong ......... God I hate to do things twice  :scared:
Have 70 challenger was 318 auto. On its way to 70 R/T S/E with 520" stroker + Dana
The correct bell would be the Aluminum for the 10.5 130 tooth flywheel..... ??
Aluminum bell and 600 +/- horses probably isn’t a good idea anyway.
But I'm not getting that on a Keith Black 8 bolt crank.....LOL Though you can get the 130 in 8 bolt. So I need to go 143 tooth flywheel (Q) and a cast iron bell or a scatter shield....... I don't like scatter shields... but that doesn't mean I'm dead set against putting one in, It's just she'll be a street Queen and never see the track.
The question is, what combination of cast iron bell, clutch fork retainer, clutch fork and zbar will get me there??? I know there are different bellhouseing ball stud brackets and so on that can be had.
Some cut -- paste / relocation doesn't scare me. But if you know the strait path, I’d really appreciate it.    I just don't want to experiment and end up with extra parts and $$ in the “God Dimit” box AGAIN!!
I have the early 70, 23 spline  with the 4.807" diameter bearing retainer.
I’d like to use the McLeod clutch, Chryco thinks so much of.
Thanks to all. Have a great day
 :burnout:
I don't suffer from insanity.
I enjoy every minute of it!
Re: Bell housing CORRECT vs what works for my car
« Reply #1 on: July 28, 2013 - 04:44:01 PM »
There are some aftermarket alum belhousings that are more beefy , I would look at those , alum bels do not seem to crack unless you have broken mounts .
 I would use the 130 tooth flywheel & the 10.95 clutch , you can get a double disc street twin McLeod with the Borg & Beck / Long clutch ,
Offline Todd Smith
« Reply #2 on: July 29, 2013 - 09:56:29 AM »
Have one you really like in mind? For the bell.
Thanks Chryco...... You're the best
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: July 29, 2013 - 12:51:58 PM »
Check out brewers, they have quite a few.
Offline Todd Smith
« Reply #4 on: July 29, 2013 - 01:50:21 PM »
Thanks HP................... been their and Passions
Offline bigblue73
« Reply #5 on: July 29, 2013 - 02:46:51 PM »
Please consider going to a blow-proof unit with 600 plus horsepower.  The idea is to contain a clutch explosion inside the can and save you a ton of money by saving your block and keeping your feed dangling from the correct point on your body.  I've never personally seen a clutch explosion but we patched a floor pan for a drag racer that went through it.  It was nasty.  Quicktime is the best for run-out and concentricity.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: July 29, 2013 - 04:44:22 PM »
I also remember back in the day there was scattershield blankets as well.
« Reply #7 on: July 29, 2013 - 05:59:26 PM »
I cannot remember the make but we ordered one a few years back very HD alum belhousing , had the name cast into the top which would not be seen against the floor .
 You could look at using a hyd clutch system also ,  NOT Keisler there is a second company making a bleedable one .
 Regular Z bar & linkage is easy also .
 I use blastsheilds or the most part .
Offline Todd Smith
« Reply #8 on: July 30, 2013 - 11:07:08 AM »
Big BlueThanks for the concern. You are probably right. I've never SEEN one come apart, but I know it happens. Be kinda like sitting on a granade and It's no more expencive than a new heavy duty
RE_THINKING............... :2thumbs:
