Author Topic: question: manual tranny - security lock - disable?  (Read 577 times)
Offline ec_co
« on: July 28, 2013 - 11:13:18 PM »
'70 Barracuda - 3spd on the floor. I'm working on pulling the project out of the weeds this weekend and seeing what shape everything is in. I want to see if I can turn the motor by hand, but I'm pretty sure the tranny is locked in reverse and we can't find the ignition keys right now (might be lost) ..... is there a semi easy way to disconnect the factory lock out mechanism?
 :working:
anyone have experience with a locksmith, and the rough cost of having a new set of keys made? just curious if it would be better (eg: more cost effective) to replace the lock sets all around, or just have someone come out and make replacements.
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Re: question: manual tranny - security lock - disable?
« Reply #1 on: July 28, 2013 - 11:48:07 PM »
just disconnect the linkage at the bottom of the column to release the shift mech
 Not that hard to pull the steering wheel & remove the ign lock , easy to make a key from that as it will be coded . Cost for a lock smith to come out will vary depending where you are but easily $100 + much easier to take the locks to them
Offline ec_co
« Reply #2 on: July 29, 2013 - 01:29:05 AM »
ok cool, so I it sounds like the "Rod - Column Lock Front" that I want to disconnect at the column linkage
« Reply #3 on: July 29, 2013 - 09:18:24 AM »
sure , easy to get too , but anywhere in the linkage will work also even disconnection it at the shift lever on the trans
