Author Topic: Modern Electronics for Ralle Guages  (Read 1227 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: July 30, 2013 - 12:39:06 PM »
Does anyone make updated electronics for the oil and temp guages for a ralle E-Body. If not they should, these guages suck big time........
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline 72cudamaan
Re: Modern Electronics for Ralle Guages
« Reply #1 on: July 30, 2013 - 10:49:56 PM »
Aftermarket gauges are made every day... what's wrong with yours? They can also be rebuilt if needed.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: July 30, 2013 - 10:56:48 PM »
 T off where the point of contact is and add under dash gauges.
Stewart Warner didn't get big for no reason.
  • I'm a llama!
« Reply #3 on: July 31, 2013 - 09:12:43 AM »
I don't want aftermarket guages, looks a little tacky in a restored car in my opinion. Just figured someone would make a matching original face guage with modern electronics on the back.
1971 Hemi Cuda
Offline ToxicWolf
« Reply #4 on: July 31, 2013 - 11:47:31 AM »
They have the amp to volt meter and the quartz clock conversion.
  • I'm a llama!
« Reply #5 on: July 31, 2013 - 01:55:55 PM »
I have done the clock, amp gauge doesn't bother me. Did the tach upgrade but it still is not very accurate.
1971 Hemi Cuda
Offline MJS73
    • Mike's 1973 Challenger
« Reply #6 on: July 31, 2013 - 03:23:25 PM »
The amp gauge should bother you, it's a potential fire hazard if you haven't bypassed it.
www.mikes73.com
  • I'm a llama!
« Reply #7 on: July 31, 2013 - 03:49:32 PM »
I see, wasn't aware of that.
1971 Hemi Cuda
Offline 73EStroker
« Reply #8 on: August 13, 2013 - 08:50:36 PM »
One way to keep the amp gauge working good is to ensure the terminal nuts on the back are kept reasonably tight so the wire lugs cannot rotate. I have mine like that and zero issues over the last 4 years.
Barry (Salmon Arm)
Offline ragtopdodge
« Reply #9 on: August 15, 2013 - 02:14:43 PM »
Just get REdline gauges to redo your AMP to a Volt, and have the Temp and Oil redone by them where they calibrate it.  Not sure if it can be made more "modern".
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #10 on: August 16, 2013 - 02:58:54 PM »
:iagree:   That and the fusable link starter relay connection should be replaced with a 60 amp maxi fuse
