Author Topic: 1 or 3 speaker dash, what deterimed what was used?  (Read 1796 times)
Offline culp71
« on: July 30, 2013 - 01:23:40 PM »
Hello all,
trying to finish all the planning before re-assembly.
My question is: I have seen 1 and 3 speaker dash pads,
what determined if 1 or 3 was used?
could any Ebody 71 cuda have either or?
thanks :clueless:
Offline Jamiez
  • Retro
Re: 1 or 3 speaker dash, what deterimed what was used?
« Reply #1 on: July 30, 2013 - 01:29:01 PM »
The radio option determines which dash was used.
AM got the single speaker
FM got 3 speaker
Offline JayBee
« Reply #2 on: July 30, 2013 - 02:47:20 PM »
I know you're asking about a '71 but I thought I'd throw this out there too.
In 1970, IIRC,  the AM/8 Track option also got the 3 speaker pad.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Jamiez
  • Retro
« Reply #3 on: July 30, 2013 - 02:58:44 PM »
FM and 8 Track were stereo options.  All the stereo options got 3 speaker dashes.
They also received 2 rear speakers if they had a rear speaker.
AM (and no radio) had a single speaker dash, and a single rear speaker if they had the rear speaker option.
Offline Haddixj
« Reply #4 on: July 30, 2013 - 04:25:29 PM »
sorry to jump in on this, but my car 71 cuda built april 71 has R35 am/fm radio came with a 3 speaker dash does it come with dual rear speakers also? or was that another option?
Offline Jamiez
  • Retro
« Reply #5 on: July 30, 2013 - 04:28:45 PM »
Rear speakers were an individual option.  If the car had them it would have had a different in dash harness (it would have 2 large 6 wire connectors) and it would have had a rear speaker fader knob with a 6 wire connector and 2 pots on it.  These are hard to come by, and the B body ones will not work (they have a shorter shaft).
If you do not have the original dash, harness or knob, the only way to tell would be to check the broadcast sheet.  There is no way to tell from the fender tag.
Offline Haddixj
« Reply #6 on: July 30, 2013 - 04:32:19 PM »
I am missing my sheet, and the car was stripped so I wont be able to tell, more then likely I will add some as I want to be able to hear the radio. Thanks for the info
