Author Topic: OK...Any Comments/ Suggestions on 6.1 Hemi with NAG1 Transmission???  (Read 13853 times)
Offline roadrunninMark
Re: OK...Any Comments/ Suggestions on 6.1 Hemi with NAG1 Transmission???
« Reply #15 on: August 17, 2013 - 03:26:07 PM »
Thanks Lonewolf,  this is the info we need!  I guess that finalizes my plans to find a wreck and use the engine, drivetrain, and everything else I can use to make it work.   :thumbsup:
Offline Lone wolf
« Reply #16 on: August 17, 2013 - 08:11:13 PM »
 Not a problem. Not sure how much technical help I can supply, but I'll try an answer any questions.
Ray
Offline 1970GranCoupeConvert
« Reply #17 on: August 18, 2013 - 05:32:12 PM »
Ray,
Can you provide some pictures of the install (pics of the dip stick conflict/ rear trans mount/ drive shaft)?
What kind of drive shaft did you run (a slip joint drive shaft like on Jeep)?
How about the shifter...did you install it inside of the stock center console?
What did you do for a speedo (GPS speedo or electric drive)?
Any pics and advice would be super...we promise we will pay it forward to some other guy on the forum!!!
1970 Plymouth Barracuda Gran Coupe Convertible
First Car (purchased in October 1985)
Drove it throughout high school and early college (still do)
Full Frame off (K frame off) Rotisserie Restoration completed in 1991
Originally (and still is) a Rally Red, Black top with Charcoal/Silver Interior
340 CID with Holley Pro-Jection 4Di
LA 727 GearVendor  Overdrive
390:1 8 3/4 Rear end
Rally Rims (color matched)
Offline Lone wolf
« Reply #18 on: August 19, 2013 - 06:07:14 PM »
Give me a day or two. I have pics with trans and drive shaft installed. I used the factory two piece shaft from the 07 charger as well as the rear. Pics are not the best, and are back out of the car for paint. I posted a link on here to some pics. It's in the gen III swap thread.
Offline ntstlgl1970
  • T a c o c a t
« Reply #19 on: August 20, 2013 - 02:57:29 AM »
As far as the keyless go (push button start) from the late model car goes, I really doubt you can make that work. You need all of the harnesses connected to the network related to the anti theft, up to and including the fuse box in the engine compartment. I know Bob (twisted fish) had a hell of a time getting support on the programming for his NAG-1. The 545RFE has much less aftermarket support than the NAG-1. My vote would be for a man trans or going for a 4L80E swap. There are so many headaches swapping this stuff since chrysler isn't helpful on the programming end. Unless you keep everything stock i.e. stock computers, stock harnesses and stock internals you may find yourself heavily dependent on someone (quite possibly not local to you) for programming your stuff. I wish we had the aftermarket support the ford and gm guys have, but we don't...
Offline KiwiChallenger
« Reply #20 on: August 24, 2013 - 07:45:56 PM »
This car is here in NZ and is running 6.1 NAG-1 combo on factory computers
http://www.v8.co.nz/articles/1969-dodge-charger-modernised-mopar-83
« Reply #21 on: September 02, 2013 - 06:52:26 PM »
 :worshippy  +  :popcorn:  + :useless:  +  :bananasmi
(Translation...Lone Wolf  we are begging you while we are eating popcorn and patiently waiting for some pics and then we will be a happy dancing bananna)
Offline Lotsapins
« Reply #22 on: September 23, 2013 - 07:07:39 PM »
Just an FYI. The headers available won't work with the NAG1 as the starter is on the wrong side. But... Good news sort of.. :crazy:
 Seems TTI has a prototype for this problem. They got a early Charger in the shop with a NAG1 and made the header. It will only work with a non torsion bar K Frame. That is what they had to work with. They want to make it work with torsion bar suspension, but are not able to get a car in for them to design on. It could have been the original posters car?? I now have to decide on using the NAG1 and changing out the k frame..... What next ???:horse:
call TTI for the info. They are very helpful and informative.
Thanks , Keith
71 Challenger Conv
Build Thread: http://www.cuda-challenger.com/cc/index.php?topic=97569.0
71' Roadrunner Stock restored 383 4spd
08 Charger SRT8 Super Bee
07 Ram 2500 4WD Cummings
