Author Topic: Need some advice.............  (Read 648 times)
Offline old-school
« on: July 31, 2013 - 11:52:55 AM »
Things have been running good with my 73 Challenger the last few years. Here's whats going on right now. I turn the key, nothing, but it will crank right up if i bridge the posts on the starter relay with a screwdriver. I replaced the starter relay yesterday and it's still doing the same thing. Also, now my turn signals don't work.....yikes! Please advise with some details if possible, i'm a ok mechanic but not so hot with wiring....thanks
Modify message
Offline TinCuda
    • 'Cuda
Re: Need some advice.............
« Reply #1 on: July 31, 2013 - 01:03:51 PM »
If you have an automatic transmission, I would start with your neutral safety switch.  You can run a jumper wire from your start relay to ground (I am going by memory, but I think it is a brown wire with a yellow stripe) to bypass your safety switch.  It should start with the key that way.  Careful because it will also start in gear that way.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: July 31, 2013 - 08:15:41 PM »
Obviously a switch in between is not working.
Can be the ignition switch if it's old and possibly the NSS as TinCuda stated.
Offline old-school
« Reply #3 on: August 03, 2013 - 11:18:22 AM »
Thanks for all of the info guys. I have a slapstick shifter with a manual valve body as far as transmission goes, will that have a neutral safety switch? If so, where is it located?
Offline FY1Cuda
« Reply #4 on: August 03, 2013 - 12:36:49 PM »
The neutral (and back-up light) switch is screwed into the driver-side of the trans.  It has a little black rubber connector with three wires leading to it.  Sometimes the rubber connector falls off, and then the car won't start with the key.
Offline old-school
« Reply #5 on: August 03, 2013 - 01:11:17 PM »
Thank you FY1! I'll check.......
