Last time I did this in the driveway I used two sturdy jacks, one under each frame in front of the forward leaf spring mount. When you take off your tires put them under the car in front of the jacks as well just in case the car falls off the jacks while you're working. I then used a floor jack to lift the weight off the center of the rear end, then on one side unbolted the shocks, ubolts rear shackles then front leafspring eye bolt. Install in opposite order of removal, then when you're finished with one side do the other. You may have to tweak the floor jack to help keep tension off the leaf springs until both ends are re-attached. That's how I did it. I can soooo relate to not being as strong as I used to be. In the past I've installed transmisions by myself without a jack .... probably won't be doing that again! Good luck & be safe!!!
Later, Jim
