Generally lower is better , dropping the nose is easy you can reset the toe in with a tape measure in the front & rear of the tires , you want about 1/16 less in front measuring from he same point in the tire , with the rear leaf spring flat it is stiffest for cornering which is why the Hotchkiss spring keep the rear low , good shocks help a lot as well
