Author Topic: exhaust manifold  (Read 959 times)
exhaust manifold
« on: August 02, 2013 - 08:45:26 AM »
Looking for a PS exhaust manifold for a 73 318.  Pick up at Mopar Nats if possible.  Thanks
Offline crocha617
Re: exhaust manifold
« Reply #1 on: August 05, 2013 - 04:15:28 PM »
I have a pair of 71's on a 318 and a random spare from another 318 kicking around just need to check which side. You can have it if you want it and can always swap it out when you find the correct dated one. Let me know.
« Reply #2 on: August 05, 2013 - 05:08:23 PM »
The dates are on the inside so you can't see them anyway.  Are you going to the Nat's?  I've got a couple people bringing manifolds there.  I want some spares since they aren't making them anymore.
Offline crocha617
« Reply #3 on: August 05, 2013 - 09:56:52 PM »
I'm not going to the nats. See how you make out while your there. If you end up needing them I can ship them to you.
« Reply #4 on: August 06, 2013 - 08:47:06 AM »
I don't think the manifold is cracked after all.  My wife had an old stethoscope that I converted to garage use last night.  It's leaking past the heat riser shaft and two holes that run perpendicular to it.  If I can't seal them up I'll let you know.  Thanks
