Author Topic: Help! No start condition  (Read 1263 times)
Offline cudasteve72
« on: August 02, 2013 - 05:31:44 PM »
I'm having trouble with the challenger.  It has the symptoms of a dead battery. Battery is good, just put new back up starter relay in, still all I get is clicking like its dead.  My next thought is starter what do you guys think.
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Re: Help! No start condition
« Reply #1 on: August 02, 2013 - 06:31:40 PM »
What does it do when you short the terminals on the relay ?
Is the yellow wire to the relay getting power , is the brown wire at the relay grounding through the Nss switch on the trans in Park ?
Offline cudasteve72
« Reply #2 on: August 02, 2013 - 06:41:23 PM »
Now it's working. We think it might actually be the battery.
« Reply #3 on: August 02, 2013 - 06:56:01 PM »
Are the connections all good , no green rot near the cable ends ?
« Reply #4 on: August 03, 2013 - 01:50:18 AM »
 :iagree:  That's what I was going to mention
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: August 03, 2013 - 03:02:09 PM »
either corrosion or a weak cell in the battery
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« Reply #6 on: August 04, 2013 - 05:28:32 AM »
Many auto parts stores will test your battery for free. Worth it to rule in or out the battery as the cause.
A simple test is just turn on the headlights. If they're dim, the battery isn't putting out the juice, or you've got bad/corroded/loose battery cables.
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: August 04, 2013 - 11:08:04 AM »
another simple test is to turn on the headlights and they look ok...but go way dim when you turn the key to start...that is normally a bad cell
It breaks down with a serious load
Offline cudasteve72
« Reply #8 on: August 04, 2013 - 01:42:17 PM »
New battery and she's good as new!
Offline BruteForce
« Reply #9 on: August 04, 2013 - 02:48:47 PM »
I love easy fixes!
BTW, I've had great success for battery longevity by using one of these:
http://www.amazon.com/Battery-Tender-021-0128-Plus-Charger/dp/B00068XCQU/
if you aren't driving the car every day. It gets me way more than the usual 5 year life. I also use one of these:
http://www.amazon.com/NOCO-ID220S-6V-24V-Battery-Disconnect/dp/B006EH9WUC/
to disconnect the battery when the car will be sitting for a while, and when I connect the charger.
« Reply #10 on: August 05, 2013 - 04:15:11 PM »
I don't use a battery tender, but I do use a cut off switch as BruteForce posted.
I have Rally gauges with an analog clock that will put a hurtin' on a battery after 3-4 weeks without driving the car.
