Author Topic: Mancini 120 amp wiring question  (Read 742 times)
Offline DocMel
« on: August 05, 2013 - 09:05:47 AM »
My old alt had 3 connections:   One larger wire   (for 12 v) and 2 smaller wires.
1.  The two smaller wires are the question:  On the new 120 amp alt, there are two small posts to attach my two small wires:  Does it matter which smaller wire goes to what post ?    (The large post for 12v is a no brainer)
Re: Mancini 120 amp wiring question
« Reply #1 on: August 05, 2013 - 09:09:06 AM »
assuming the new alt is unregulated internally they are just the field connections so power in & power out to the regulator which controls the groun for the field so it doesn't matter which wire goes where .
Offline DocMel
« Reply #2 on: August 05, 2013 - 01:37:26 PM »
Gotcha  It is ext regulated, so no brainer, thanks
« Reply #3 on: August 05, 2013 - 11:32:18 PM »
 :2thumbs:
