Author Topic: Horn button assembly with a crush can?  (Read 1345 times)
Offline Strawdawg
    • Vortex Buicks
« on: August 05, 2013 - 02:13:16 PM »
Does anyone have any pictures showing how the horn is assembled on a crush can column on a Challenger?
I am starting with a column that had no crush can and had a Grant wheel on it.  The wheel was up against the dash pad lip and had no horn connected.  PO used a separate button on the bottom of the dash.
I installed a crush can and have a Tuff Wheel look alike on order which is drilled for the Mopar can as well as the standard Grant pattern.
I ordered a horn button retainer and a Tuff Wheel horn button contact assembly.
I am wondering what else I need plus how it all goes together.
A picture might be worth a few words :)
Re: Horn button assembly with a crush can?
« Reply #1 on: August 06, 2013 - 04:38:37 PM »
the horn button screws onto the steering wheel with 3 very small machine screws , the horn pad just snaps onto the horn button , the ground wire comes up from the can into the horn switch
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: August 06, 2013 - 05:14:09 PM »
Thanks, Neil!
Offline JayBee
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: August 06, 2013 - 07:19:11 PM »
thanks, I found another one on ebay last night with some good pics....it's bad when we use ebay for tech info but any port in a storm!  :)
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: August 07, 2013 - 12:34:17 AM »
I have a wheel with the horn button still attached if you need pictures of something?   :2thumbs:
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: August 07, 2013 - 10:15:47 AM »
I think I am good now...but I appreciate it and will drop you a note if I have a problem.  Waiting on parts at the moment :)
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: August 07, 2013 - 01:53:24 PM »
Just got my horn contact plate in...pretty obvious how it works!  shoulda been patient  :D
Beats the heck out of a Grant horn kit
Offline ToxicWolf
« Reply #8 on: August 07, 2013 - 03:30:01 PM »
Would you mind telling me where you got the parts from? I'm in almost the same position. Car had a grant wheel and the crush can was in the trunk. I have a tuff wheel clone but still need horn parts ... plate, etc.
If you click my restoration link in the sig and go down to the second picture you will see where I started.
« Last Edit: August 07, 2013 - 03:55:47 PM by ToxicWolf »
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: August 07, 2013 - 07:35:42 PM »
http://www.ebay.com/itm/281117240841?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
this is Dale's Cuda Shop
Not obvious unless you know what you are looking at but it includes both the contact plate and the three legged horn button retainer.  Horn button should have fingers in the center that pop into the circular hole on top of the retainer.  When you press the the horn button, it tilts the retainer and makes contact with the plate to complete the circuit
Offline ToxicWolf
« Reply #10 on: August 07, 2013 - 09:07:27 PM »
That's perfect.  Thanks Steve.
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: August 07, 2013 - 09:37:50 PM »
Glad I could help  :)
« Reply #12 on: August 07, 2013 - 11:28:31 PM »
A lot of the Dodge trucks used the same horn switch with a similar horn pad into the 80s
