I've thrown out the Hooker Super Comp Headers I had on it, and bought two stock HP exhaust manifolds. Reason for that was I had to remove the starter, and it was basically sitting behind bars with those headers on, and then as if that was not enough I had to work really hard to even get the headers off it cause theres no room for anything anywhere down there. I'm no gynocologist, and I just cant work under such conditions so I threw it out.
Now ofcourse, I face a new problem. On the passenger side manifold. How the hell am I supposed to get a nut on that one screw that sticks out of the block...? You cant get a socket into the hole that will also fit the nut ?
Also - is the threaded holes in the block where you fasten the exhaust manifold connected to the coolant area? If you leave a screw out, will coolant come out that hole? It seemed like it did on mine..?
