Author Topic: Starter relay inline fuse  (Read 1754 times)
Offline Chooch
« on: August 11, 2013 - 12:03:11 AM »
Hello fellow Challenger owners. Iam having a small issue that is kicking my butt. I have a 25 amp inline fuse connected to my starter relay. All of a sudden I can only start the car once, the fuse blows and the car continues to run however when I turn the car off iam unable to start it again until I replace the inline fuse. The car is a 73 Challenger 340. It seems so simple. Help
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Starter relay inline fuse
« Reply #1 on: August 11, 2013 - 07:30:48 AM »
Why do you have a fuse in there?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #2 on: August 11, 2013 - 07:45:27 AM »
On the stock wiring there should be a fusable link. If I remember right I think it is 30 amps. If you have a 25 amp fuse it might be too low.Especially if you have any accessories turned on when you start it.  I replaced mine with a 60 amp Maxi fuse which is much safer and more servicable.
« Reply #3 on: August 11, 2013 - 10:55:02 AM »
the fusable link feeds the rest of the car not the starter relay , there should not be a fuse in there
« Reply #4 on: August 11, 2013 - 08:28:53 PM »
Get rid of that fuse. It shouldn't be there.
Offline Chooch
« Reply #5 on: August 11, 2013 - 09:11:11 PM »
Thank you so much for taking the time to help me. I shall make the repair. Good luck to you
