LITTLE HELP PLEASE!! BOUGHT A 70 440 CHALLENGER LAST WEEK, CAR HAS BEEN SETTING ABOUT 5 YEARS!! CHANGED PLUGS, OIL , FILTER, CLEANED TANK, FUEL FILTER, GOOD GAS!! CAR FIRED UP FIRST TRY. GOOD 65-70 LBS OIL PRESSUE. I DROVE THE CAR AROUND THE BLOCK A FEW TIMES TRYING TO FIGURE OUT WHAT ALL WAS NEEDING TO BE DONE. DROVE THE CAR A COUPLE MILES LAST NIGHT ( OIL PRESSURE WAS FINE). STARTED THE CAR THIS MORNING , STARTED RIGHT UP ON FIRST TURN. NO OIL PRESSURE AT ALL. MANUAL GAUGE SO I PULLED THE LINE FROM THE BLOCK, TOOK COIL WIRE OFF, TURNED ENGINE OVER, NOTHING CAME OUT, SWAPED OIL FILTER AGAIN, NOTHING, REMOVED SPRING AND SEAT FROM SIDE OF OIL PUMP( NOTHING WRONG THERE). I'VE ORDERED A NEW OIL PUMP. THE ONLY THING I CAN THINK OF IS THE PUMP WENT OUT OR THE PICK UP CAME OFF THE BLOCK!!! IS THERE SOMETHING ELSE I MIGHT BE FORGETTING?? IT'S BEEN 35 YEARS SINCE MY LAST MOPAR!! I'M A LITTLE RUSTY!!!! ANY ADVICE WOULD BE GREAT!!!! THANKS- JIMMY
