Author Topic: HELP NO OIL PRESSURE  (Read 1912 times)
Offline Strawdawg
    • Vortex Buicks
Re: HELP NO OIL PRESSURE
« Reply #15 on: August 11, 2013 - 08:41:18 PM »
kinda hard to believe that the port is plugged with the pressure it sees?
Offline anlauto
« Reply #16 on: August 11, 2013 - 08:47:23 PM »
If no oil up top or the drill spins freely in the pump, then you will have to pull the pan and check the pick up but I think it is unlikely to have come out given that it is threaded.
That's a good idea too, if you have a priming shaft you could spin the pump and see what happens without turning the motor over....Run it both ways too to clear any blockage...
The pick up doesn't have enough room to fall off...
Offline soda4u2
« Reply #17 on: August 11, 2013 - 08:54:28 PM »
I'm open to all of your suggestions.
I ordered a new melling
HV pump, should be here tomorrow. That will eliminate one problem for sure and start working towards the top! I'M trying all of your suggestions, one of them will fix it so I can drive it.
Offline Strawdawg
    • Vortex Buicks
« Reply #18 on: August 11, 2013 - 08:57:34 PM »
I have not used a hv pump but many suggest the beefed up drive shaft to prevent breaking the normal one...lot more force on the drive given the taller gears
Offline soda4u2
« Reply #19 on: August 11, 2013 - 09:00:00 PM »
OK
! I'll keep everyone posted. When I find the problem everyone will know what it was!!
Offline 72cudamaan
« Reply #20 on: August 11, 2013 - 09:10:00 PM »
Silly question.  Are you sure there is enough oil in the Pan? I've seen stranger things.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline soda4u2
« Reply #21 on: August 11, 2013 - 09:44:04 PM »
It's shows full on the dipstick. But it had 60lbs yesterday.
« Reply #22 on: August 11, 2013 - 09:51:14 PM »
I have seen the oil pumps refuse to reprime after a filter change also could be a problem with the filter , I hope you are Not using Fram
« Last Edit: August 12, 2013 - 02:48:41 PM by Chryco Psycho »
Offline dutch
« Reply #23 on: August 12, 2013 - 01:24:55 PM »
might be a leak in the pipe. Possibly loose and hit my the crank or rod
*** Bart ***
Offline anlauto
« Reply #24 on: August 12, 2013 - 01:27:49 PM »
I still want to know if the sign on no oil pressure is just the gauge or is the motor noisy as heck ?
Offline Strawdawg
    • Vortex Buicks
« Reply #25 on: August 12, 2013 - 02:27:12 PM »
x2
Offline 73EStroker
« Reply #26 on: August 12, 2013 - 02:29:19 PM »
Perhaps a big piece of dried oil sludge is blocking the pickup. Worth checking but the pickup screen may have taken care of that.
Barry (Salmon Arm)
« Reply #27 on: August 12, 2013 - 02:50:01 PM »
I thought he had removed the sender / line at the rear of the block & there was no oil getting there ?
Offline Strawdawg
    • Vortex Buicks
« Reply #28 on: August 12, 2013 - 04:04:03 PM »
he did, but the question arose regarding the possibility of the port being clogged which would seem to be remote given the pressure at the port, but I guess it could be possible
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #29 on: August 13, 2013 - 04:27:08 AM »
 :popcorn:  I'm curious too, good learning time!  Thanks!
