Author Topic: high ambient temps and pinging  (Read 904 times)
Offline ff6849
« on: August 12, 2013 - 12:28:37 PM »
Will outside air temp affect/cause pinging under heavy acceleration?
I recently got the car running this January, it has been running quite well. But the other day while driving its pinging  under acceleration, it seemed worst when with the A/C on too. The outside temp was well over 100'  8) (welcomed  to the desert southwest, but I will be cursing all winter long  just trying to survive June-August).  Will the high ambient temps cause this situation, I am running premium fuel 91-92 octane.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline Strawdawg
    • Vortex Buicks
Re: high ambient temps and pinging
« Reply #1 on: August 12, 2013 - 02:28:07 PM »
yes, particularly if the coolant temp is way up there
« Reply #2 on: August 12, 2013 - 02:48:05 PM »
using a cold air inlet to the carb can help reduce temps inside the engine .
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: August 12, 2013 - 04:02:22 PM »
yep, forgot to specify that hot air, while less dense which makes the engine richer, is easier to ignite so a cool air system helps a lot
Offline ff6849
« Reply #4 on: August 12, 2013 - 04:07:12 PM »
what options are available for cold air systems for a 73 'Cuda
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
« Reply #5 on: August 12, 2013 - 06:31:54 PM »
Build you own , dryer tubing hood scoops opened , any airflow possible through the engine compartment helps
Offline msbaugh
« Reply #6 on: August 12, 2013 - 06:44:50 PM »
Has anyone on here ever made the scoops on their e-body functional for that purpose? Seems like a cool project! I would love to see it
Offline msbaugh
« Reply #7 on: August 12, 2013 - 08:30:27 PM »
this is the most effective way to get cold air  :roflsmiley:
« Reply #8 on: August 12, 2013 - 11:34:11 PM »
Sure Cardboard should be effective  :smilielol:
 The most efficient place is a front air dam AAR/TA style or the base of the windshield / Nascar style , using dams around the car helps as well creating a vacuum under the which helps both aerodynamically & pulling heat out of the engine compartment from below .
Offline cudabob496
« Reply #9 on: August 13, 2013 - 03:13:06 AM »
www.ramairbox.com
« Last Edit: August 13, 2013 - 03:16:45 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
« Reply #10 on: August 13, 2013 - 03:19:38 AM »
if pinging, use high octane gas, dial back timing a few degrees, aluminum radiator
will keep engine cooler, lower thermostat.
2011 Kawasaki Z1000
