Author Topic: Oil Pump Drive Support Bush  (Read 929 times)
Offline Aussie Challenger
« on: August 14, 2013 - 08:43:19 AM »
I was checking an article on rebuilding my small block and it said that I have to use a special tool to size the bush once I have knocked it into place. I have always been told to just tap it with a drift and hammer into place, I have never replaced one before as the shafts have always been quite tight and not needing replacing. I can see how the tool works and why, similar to sizing K line valve guides, so is it necessary?   :working:
  Thanks in advance.
   David
   Aussie Challenger
Re: Oil Pump Drive Support Bush
« Reply #1 on: August 14, 2013 - 09:04:34 AM »
I had one where the oil pump drive was very tight in the bushing after it was installed.  I assume this is what they are talking about.  If the pump drive slides into the bushing without binding, then I think you should be ok. Someone with more experience should confirm this.
« Reply #2 on: August 14, 2013 - 09:10:59 AM »
usually once the bushing is installed the bushings is too tight for the drive to slide into it so the only choice is to burnish it open again
« Reply #3 on: August 14, 2013 - 09:55:11 AM »
Thanks to both of you for your quick response, C.P. I got that from the article so I suppose if I have to replace the bush, I do have a new one, I will have to address "burnishing" the bush. Either find a tool (make one, buy or borrow), it said not to ream out the bush as it will not hold properly in the block without burnishing.   :2thumbs:
