Author Topic: Backwards wipers?  (Read 889 times)
Offline Fern
Backwards wipers?
« on: August 14, 2013 - 05:43:56 PM »
Ok, got my wipers in and when I turn them on they go down instead of up.  When I turn them off they park up.
I hope its an easy fix?
Thanks
Offline Rich G
Re: Backwards wipers?
« Reply #1 on: August 15, 2013 - 04:38:52 PM »
sounds like the link on the motor is 180 off
Offline polarbear123
« Reply #2 on: August 15, 2013 - 04:45:19 PM »
Make sure your transmission, motor and switch or all 3 speed or 2 speed. I had a 2 speed switch with a 3 speed motor that tried to park when you turned it on.
Offline Fern
« Reply #3 on: August 15, 2013 - 05:32:40 PM »
I'll give it a shot.
Thanks
Offline Fern
« Reply #4 on: August 16, 2013 - 05:22:56 PM »
ok, the issue is that they dont park all the way, when I shut them off they go backwards but not all the way, if i use my hand they will go all the way but need help.
Do I need to rebuild this?
Anyone with the same problem?
« Reply #5 on: August 16, 2013 - 07:37:06 PM »
Seems to be a common problem , if the wipers stay up it can burn out the motor .
If you have to rebuild kim @ Passion 4 mopars is the go to person
« Reply #6 on: August 17, 2013 - 07:51:36 AM »
Are they getting hung up on the wide chrome trim at the base of the windshield? I had to stick my trim piece down with a small dab of silicone so the wiper arm on the driver's side would clear.  :2cents:
Offline Fern
« Reply #7 on: August 17, 2013 - 01:24:46 PM »
I pulled the wipers off. It seems like its inside the motor, I think something is worn.
I have an email to Kim at passion and am awaiting a response
