Author Topic: Rims, Tires and Suspension  (Read 4219 times)
Re: Rims, Tires and Suspension
« Reply #15 on: August 16, 2013 - 12:44:07 PM »
8 wide 4.5 b.s.
The backspace is the key part of it all. If you pickup an 8" deep dish with only 3.75 backspace, it isn't going to work. If you use a later model 8" with 6" of backspace, it isn't going to work. You want to stick with 4.5" backspace. If you step down to a 4.25" backspace, you may be limited to a 255 width tire.
Offline dvldwg89
  • Semper Fi
« Reply #16 on: August 16, 2013 - 01:26:29 PM »
There's another set of 14" road wheels on Moparts. Check out the "wheels and tires" section.
Thanks Burder. I'm going away from 14 inch rims. Tire choices are slim for 14s.
Offline dvldwg89
  • Semper Fi
« Reply #17 on: August 19, 2013 - 04:53:10 AM »
:2thumbs: Rodger that. Rears will be 8 inch with 4.5 backspace. If I put 8 inch up front what backspace there? Prolly a 235/60 15 tire.
« Reply #18 on: August 19, 2013 - 09:16:05 AM »
If you go 8" all around, then 4.5" will fit all around. if you go 7" up front, then you can back off to 4.25 without any problems.
Offline dvldwg89
  • Semper Fi
« Reply #19 on: August 19, 2013 - 05:51:16 PM »
Thanks
Offline dvldwg89
  • Semper Fi
« Reply #20 on: August 20, 2013 - 06:10:09 PM »
This is the rim I'm thinking of getting.
« Reply #21 on: August 20, 2013 - 09:55:19 PM »
 :2thumbs:
