Author Topic: fuel line  (Read 762 times)
Offline rattlesnake
  • Rattlesnake
fuel line
« on: August 18, 2013 - 08:03:48 PM »
Will a 5/16" primary fuel line provide enough fuel for a mildly modified single 4 barrel (holley 850) 440? I am expecting the engine to produce 450 to 500 HP. Should I go to a 3/8" line? Also does anyone know how to make the expanded flare on the end of the fuel line so a rubber hose can be connected to the line to eliminate leaking?
thanks Ray
keep honking I'm reloading
Offline Strawdawg
    • Vortex Buicks
Re: fuel line
« Reply #1 on: August 18, 2013 - 08:37:12 PM »
I would use 3/8's.   Not sure about the flare...I just double clamp them
Re: fuel line
« Reply #2 on: August 18, 2013 - 09:20:30 PM »
I use a double flare & swell the tube with no sharp edges , slide the hose over & clamp it
Offline Racer57
Re: fuel line
« Reply #3 on: August 18, 2013 - 10:17:50 PM »
thanks Ray
Most places like Ace, Home Depot, NAPA,  etc carry the tools required to do it. Their cheap to buy and easy to use.
Offline cudabob496
Re: fuel line
« Reply #4 on: August 19, 2013 - 01:21:18 AM »
unless you are running the quarter mile full throttle, I would think you 5/16 would be fine.
As long as you got a good fuel pump,and clean fuel filter, you should be ok.
A fuel pressure gauge in the car can really help you know for sure.
Sometimes the fuel sending unit sock filter in the gas tank can clog up.
« Last Edit: August 19, 2013 - 02:37:07 AM by cudabob496 »
2011 Kawasaki Z1000
