This weekend I worked on the metal tabs on the firewall. Blasting had damaged the rubber coating on the tabs and they were all bent out of shape.
I burned the existing rubber off of them and straightened them out in my vise.
I read where someone suggested putting heat shrink tubing on the ends before dipping them so that's what I did. I'm not sure that was necessary.
I also cleaned up the brake distribution block. It looked pretty nasty to start with.
After the initial cleaning.
I tried removing the brass plug at the bottom but it didn't want to budge. I ended up just flushing it out and making sure that the internal valve still moved freely. After polishing the brass with steel wool, I RPMed the bracket and lubed the inside with brake fluid. It turned out nice.
