Author Topic: Look what followed me home today...  (Read 82697 times)
Re: Look what followed me home today...
« Reply #330 on: November 03, 2016 - 09:00:03 AM »
Thanks Tony!
I installed the springs and rear end last night.  I wasn't going to install the rear end until I had the brake hose brackets installed but I changed my mind.  It looks like shock clearance is going to be tight.  I thought it would be a good idea to install the rear now so I could measure how much clearance I actually have.  This picture is with the car suspended by the springs.  I have 11" from the axle center line to the wheel lip.  A 20" wheel should measure 21" from lip to lip so that means the top of the wheel will just disappear in the wheel well when the full weight of the assembled car is on the springs.  Right now the front spring bolt is in the lower hole.  I still have the option of moving the bolt to the upper hole which will lower the rear even more.  The rear height all depends on how low I can get the front.
« Reply #331 on: November 03, 2016 - 03:06:25 PM »
Just playing around with the cheap paint program on the computer and dreaming that I can afford these wheels. :lol:  They are Coddington HR-01s.  I like it!
Offline Cudakiller70
« Reply #332 on: November 03, 2016 - 03:18:07 PM »
Nice! Love those! Like that wheel look.
The above is just my opinion
John Adams
Offline marc70challenger
« Reply #333 on: November 06, 2016 - 01:42:12 AM »
 :ylsuper:  looking awesome man.
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #334 on: November 06, 2016 - 05:08:20 AM »
They are going to look real nice when on the car .  Please post photos when finished  :cheers: :aussie:
Go 4 a spin Ya Why Not.
Offline usraptr
« Reply #335 on: November 21, 2016 - 08:13:04 PM »
Looking good!   :2thumbs:
(Edited 8-1-17)
« Reply #336 on: January 14, 2017 - 11:54:35 PM »
I ordered front brakes a couple weeks ago.  I got the DS mounted tonight.  I think these brakes will look decent.  The rotor centers need to be painted black though.  There's just too much zinc right now.  I might also paint the calipers the same color as the engine.  It will look good against the blue body but won't be too distracting.
Now I can measure for wheels.  Just a quick check shows a little more than 5.5" from the mounting face of the rotor to the outer tie rod end.  The drop spindles I have use a through bolt with a tapered head to attach the lower ball joints.  That makes you put the nut on the inside.  With the bolt in its current location, it hits the sway bar tabs on the lower control arms.  I need to hook up the tie rods/center link and run the steering box lock to lock to be sure but I think I'm going to have an issue.  At minimum, I'll need to trim off the bolt.  If it still hits, I might have to try and find a thinner nut.
Offline 7212Mopar
« Reply #337 on: January 15, 2017 - 11:19:36 AM »
Looking good. I need to double check my measurements but that is the exact brake setup front and back I am thinking.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
