Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Rallye wiring vs. Standard wiring
« previous
next »
Print
Pages: [
1
Author
Topic: Rallye wiring vs. Standard wiring (Read 2416 times)
shatar4
Full Member
71 Challenger
on:
March 30, 2005 - 10:23:04 AM »
I will be selling my rallye gauges to buy a set of standard gauges but I need to know if the wiring harness is the same on both gauges or are they different.
Logged
1971 Triple black 340 Challenger
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Rallye wiring vs. Standard wiring
Reply #1 on:
March 30, 2005 - 10:37:32 AM »
They have to be different since the standard setup doesn't have a tachometer. That might be the only difference though. I think you are safe.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 30, 2005 - 10:48:27 AM »
basically they same , the wires are color coded & just hook to the correct locxations & the tach wire will be spare
Logged
Katfish
Resident
70 Challenger
Reply #3 on:
March 30, 2005 - 11:31:36 AM »
You'll also need to add a light bulb socket for the oil warning light, rallyes have a gauge.
Logged
4drbrnko
Full Member
Reply #4 on:
March 30, 2005 - 11:40:15 AM »
I'm curious, why do you prefer a standard gauge package over the Ralley? Usually it's the other way around, I'm changing from standard to Ralley. :dontknow:
Logged
<-------<<< Clickylinks.....
My vehicles
shatar4
Full Member
71 Challenger
Reply #5 on:
March 30, 2005 - 11:51:23 AM »
http://www.cuda-challenger.com/smf/index.php?topic=9333.0
Logged
MAXcuda
Jr. Member
Reply #6 on:
March 31, 2005 - 09:56:14 PM »
Here's how to convert a standard harness to a rallye harness:
change oil pressure senders
cut the wires off the oil light
connect the grey oil light signal wire to the oil gauge
connect the dark blue oil light wire to the tach power. (This wire is 12V ignition switched)
run the tach signal from the negative coil post to the tach
splice 12V continuous power from the cigarette lighter to the clock
Logged
MoparMatt383
Jr. Member
Member as of March 2004
Reply #7 on:
April 09, 2005 - 04:20:35 PM »
Probably you already know this, but you have to change the light bar to the standard light bar. I think the ralley and standard light bars aim the light in different spots.
Matt
Logged
Too many projects and nothing gets done.
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
April 10, 2005 - 11:43:52 PM »
4 lights in a ralley panel , 3 in the std panel most people never cahnge them
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
