Author Topic: Hood hinge spring  (Read 862 times)
Offline smallblock
Hood hinge spring
« on: August 20, 2013 - 02:18:05 AM »
Anyone know of a good and somewhat safe way to get a hood hinge spring back on with the hinge still on the car. Its a 74 Challenger.
Offline Jamiez
  • Retro
Re: Hood hinge spring
« Reply #1 on: August 20, 2013 - 06:37:40 AM »
I'm sure someone makes a tool for this, but I've always just used a jack and a lot of shims.
Extend the spring using a jack.  I hook one end of the spring around the axle of my floor jack, and the other around the lifting part.
Once it is extended (larger than you need it) insert shims between the coils of the spring.
Once you have inserted enough shims (I try to get one between each coil), slowly back off the jack.  The spring should then rest on the shims and stay extended.
Install one end of the hinge on the car, you should be able to put the other end in position, but it will not stay because the spring is still extended.  You may need to break off one end of the shims depending on how they were oriented and how long they are.
Remove the shims one at a time.  I find it is is best to remove a shim from each end and work towards the middle.  As the shims are removed the spring will contract, eventually hooking into position.  You can move the hood up and down to change when the spring hooks in.
Finish removing the shims, the fewer you have the more difficult this becomes.  You can move the hood up and down to force the spring to extend, when you have just a few left you should be able to just close the hood and the last few shims will drop out onto the floor.
Offline dutch
« Reply #2 on: August 20, 2013 - 07:32:45 AM »
hang one side to the hinge and just pull it on with a rope.  worked for me
*** Bart ***
« Reply #3 on: August 20, 2013 - 08:44:55 AM »
Me too. But use decent rope.  :icon16:
Offline daveh
« Reply #4 on: August 20, 2013 - 10:44:51 AM »
The rope is the way to go.  I've been doing it for 30 years ever since high school when tools were at a minimum.  Just wrap enough around your hands to get a good grip.  Good luck.
Offline mopar jack
« Reply #5 on: August 20, 2013 - 11:02:09 AM »
I use an old fan belt, fold it in half and it gives you two handles to pull on. If you are removing springs make sure you have the hood supported in the up position. A bumper jack is a great way to stretch a spring so it can be painted between the coils.
Offline smallblock
« Reply #6 on: August 24, 2013 - 12:35:22 PM »
Didnt have any rope so I used an old mower belt. Worked great, easy as pie. Thanks!
