Author Topic: 1970 Cuda Emblem  (Read 972 times)
Offline polarbear123
1970 Cuda Emblem
« on: August 21, 2013 - 11:03:24 AM »
Could somebody give me the placement measurements for the Cuda Emblem inside drivers door.
Thanks
Offline rattlesnake
  • Rattlesnake
Re: 1970 Cuda Emblem
« Reply #1 on: September 03, 2013 - 03:34:47 PM »
Are U referencing the emblem on the door panel? If so, do you want the measurements for the emblem or measurements for placement?
keep honking I'm reloading
« Reply #2 on: September 03, 2013 - 03:45:36 PM »
Yes  the door panel placement.
Offline rattlesnake
  • Rattlesnake
« Reply #3 on: September 15, 2013 - 07:56:54 AM »
Yea I can get this if you still need it. Sorry for the delay been out of town. I will get the measurements tomorrow when I get home.
Ray
« Reply #4 on: September 15, 2013 - 08:00:44 PM »
Great thanks!
Offline rattlesnake
  • Rattlesnake
« Reply #5 on: September 16, 2013 - 08:57:20 PM »
I just recently downgraded to a flip phone so The pictures I took are worthless so I did not bother posting them, but I think I can talk you through it and you will be fine.
Of course the emblem runs left to right, so on the drivers side the A is closest to the hinge and on the passenger side the C is closest to the hinge.
On the drivers side I measured from the front edge of the door panel (hinge side) to the edge of the A. that measurement is 5 3/4. I also measured from the bottom edge of the panel to the bottom of the letters and that measurement is 14 1/4 shy. That measurement is consistent all the way across.
On the passenger side I measured from the front edge of the panel (hinge side) to the C That measurement is 5 1/2 (A little different from the drivers side but I am guessing they accounted for the punctuation so the word itself would look right side to side) and the measurement from the bottom edge to the bottom of the letters is the same at 14 1/4 shy.
After I did this I thought what you really need is measurements to the center of the holes. If you prefer that, I can get those for you cuz I need to take the drivers side panel off anyway to install a remote mirror I engineered, at that point I can remove the emblem real quick and pull measurements for the hole centers. I won't have time to do this for another day or two. Just let me know what you need.
Ray,
« Reply #6 on: September 18, 2013 - 06:28:25 PM »
That will work, thanks for the help.
