Author Topic: Differential Recomendation  (Read 2618 times)
Offline daveh
« on: August 21, 2013 - 10:03:09 PM »
Hi Guys,
I'm considering switching my differential during the rebuild from my current 3.23 set up.  I'm running a mildly modified 340 with a Keisler 5 speed, TKO 600 and 255-60-15's in the rear.  What do you think, 3.55's or 3.91's?  Will I notice that much of a difference going from 3.23 to 3.55 if I go that route?  This will be purely street driven.  Whatever information you can give me is always appreciated.  Thanks
Offline msbaugh
Re: Differential Recomendation
« Reply #1 on: August 21, 2013 - 10:17:10 PM »
With the over drive 5 speed I would go for the 3.93s!! There's a 3.73 ratio too just harder to find. It'll make a pretty big difference and it'll be hell of a lot of fun street driving stop light to stoplight. Do you have an 8 3/4? Go with dr diff!! I got his third member with a Detroit true trac sure grip. I freaking love it!
Offline ToxicWolf
« Reply #2 on: August 22, 2013 - 04:05:04 PM »
Hi Guys,
I'm thinking the same thing. I don't know how to do the math, but I'm afraid that with the 3.23 I'll be going 70 or 80 at 1000 rpm with the 5th gear.
Offline daveh
« Reply #3 on: August 22, 2013 - 04:58:31 PM »
I had 3.73's in my 69 Z/28 and thought they were perfect.  I think the 3.55's just won't show that much of a difference over the 3.23's.  So if I can get 3.73's I'm going with those if not it's going to be the 3.91's.
Offline ToxicWolf
« Reply #4 on: August 22, 2013 - 05:27:06 PM »
If you find the 3.73 let me know where I can get some too.  :cheers:
Offline msbaugh
« Reply #5 on: August 22, 2013 - 05:57:45 PM »
One of those eBay guys had a couple I think last time I checked... They might add a hundred bucks or something since they're harder to get ahold of
Offline daveh
« Reply #7 on: August 22, 2013 - 06:38:59 PM »
Thanks
« Reply #8 on: August 23, 2013 - 07:22:26 PM »
What is the ratio in 1st gear ?? you may find it low enough without swapping the rear gearing
Offline ToxicWolf
« Reply #9 on: August 23, 2013 - 08:08:33 PM »
Rear is 3.23
First is 3.27
Second is 1.98
Third is 1.34
Fourth is 1.00
Fith is 0.68
FROM THE KEISLER SPECKS
I was just wondering what the rpm would be when we are at 65 mph in 5th gear. We have the same setup. I am concerned that the rpm in 5th gear may be too low at 60 to run in 5th without changing the rear end.
« Last Edit: August 23, 2013 - 08:23:28 PM by ToxicWolf »
« Reply #10 on: August 23, 2013 - 08:12:29 PM »
Standard  1st gear is 3.27 road race and close ratio is 2.87
Depending on what tire your using your hwy rpms at 65 mph will be around 1800 rpm's which might be a little low depending on what your cam likes? ( it might " lug" at 1800 rpms)  mine does with the 4 speed auto OD engine is "happy" at 2400 and up, problem is that's about 75 mph for me and most guys in blue frown on that!  :grinno:
I'd go with 3.91 as that will rev at about 2200 at 65 mph. If we were closer I'd lend you my 3.91 gear pot to try out first.
« Last Edit: August 23, 2013 - 08:14:56 PM by brads70 »
« Reply #11 on: August 23, 2013 - 08:18:20 PM »
Offline ToxicWolf
« Reply #12 on: August 23, 2013 - 08:26:06 PM »
Offline ToxicWolf
« Reply #13 on: August 23, 2013 - 08:49:59 PM »
Try this to figure out rpms...
http://keislerauto.com/speed_analyzers.php?sa=mopar_5
Yes, the calculator said the same thing. At 1800 rpms we would be going 65 mph. If we wanted to be really legal and go 55 mph we would be turning about 1600 rpm. I don't think she would like that at all.  :clueless:
« Reply #14 on: August 24, 2013 - 04:34:30 AM »
I wish I had picked 3.73 gear ratio when I bought the new Dana, with my combo to get the rpms up a little at hwy speeds. The thing that makes it ok/bearable is that with the auto I can simply select with the tranny controller when ( at what rpm) the convertor locks up. Driving 55 is painful for me.... the car just wants to go. Around town and slower speeds I don't put it in OD.  :2cents:
