Author Topic: Differential Recomendation  (Read 2617 times)
Offline Tonker1
Re: Differential Recomendation
« Reply #15 on: August 24, 2013 - 09:38:27 AM »
I have similar set up to you and my car will be a daily driver.
Engine:                        stock 340
Trans:                          TKO 600
1st:                              2.87
5th:                              0.64
Diff:                              8 3/4, 489 case
Ring and pinion gears: 3.23
Rear Tires:                    255/60/15, dia 26.80"
With the current set up, the car would have to going 93mph for the engine to be revving at a comfortable 2400 rpm when in 5th gear. This is a ridiculous set up.
With lower diff gears you'll find the car accelerates a whole world faster and will be a lot more fun. That is why when I've finished spending money getting the car ready for registration I plan on some performance upgrades. One of the best bolt on bang for your buck upgrades is lower diff gears. Currently I'm set on Strange Engineering's 4.10's http://www.summitracing.com/parts/str-rs03-887410l/overview/.
I know you said your car is for street use, but this article by Car Craft has an ET comparison table for various diff gears. The table is worth a look, it's at the very bottom of the article. http://www.carcraft.com/techarticles/ccrp_9812_all_about_axle_gears/viewall.html
Offline ToxicWolf
« Reply #16 on: August 24, 2013 - 10:59:19 AM »
Engine:                        stock 340
Trans:                          TKO 600
1st:                              2.87
5th:                              0.64
That's the same tire size I have on mine now.  Good info ... thanks. :burnout:
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline joelson6
« Reply #18 on: August 24, 2013 - 05:47:42 PM »
just to give you a base line.............
i had 28" tires with 4.10 gears and 1:1 with my 4 speed, 60 mph was 3000 rpm
i switched to 3.73 gears, 3000 rpm was about 65 mph.
i now have 26" tires with the 3.73 gears and i'm back to 60 mph at 3000 rpm.
you should really notice a difference between every gear ratio. each gear should have approximately 5 mph difference,
now factor in the o.d. for your final drive ratio. another thing to remember is with the tall 1st gear and matching that with a
set of 3.73 or 3.91's, you might have a hard time keeping the tires on the pavement. then you'll need to run drag radials
all the time, which isn't all that bad but they do wear fast.
i got my 3.73's (498 case) from summit for around $210
Offline mr_340
« Reply #19 on: September 21, 2013 - 07:35:27 AM »
Offline 73EStroker
« Reply #20 on: September 23, 2013 - 09:32:26 PM »
I am running a 28" approx tire with 3.73 gears in my Dana. With the Passon hemi OD and 0.8 4th gear I ran about 3000@80mph. Now my new Passon 5 spd has a 0.7 5th gear OD so we wait to skew as I am waiting to drive this thing.
Barry (Salmon Arm)
Offline ShelbyDogg
« Reply #21 on: September 23, 2013 - 09:45:50 PM »
I would stick with the 3:23s.  I've had 3:55s behind my OD, then switched to 3:23s behind my 440. It just made it faster and lowered my rpm at my 70 highway cruising speed to about 1900
I my vert, I have 2:76s behind my OD and cruise at 1800 rpm at 70 mph.
Both cars have 295-50-15 tires. Both of mine are fuel injected so they don't "buck" at 1800 rpms.
Were you not happy with the acceleration of your 5sp and 3:23s?
Offline V02Barracuda
« Reply #22 on: September 25, 2013 - 01:12:51 PM »
Dave,
I have the same engine/trans/gears/tire size as you.  The 3.23's just aren't cutting it.  Lugging too much.  I'm switching to 3.91's soon.  With 255/60/15's you'll turn 2307rpm at 70mph.
3.91's get my vote.
Good luck.
