Author Topic: Electric fuel pump  (Read 1163 times)
Offline Superbirddoug
  • Superbirddoug
Electric fuel pump
« on: August 22, 2013 - 07:43:24 PM »
When adding an electric fuel pump can you leave the mechanical fuel pump on? Meaning the electric pumps thru the mechanical and the mechanical pulls thru the electric. If either quits you still have fuel.
Thanks in advance
1970 Challenger t/a
1969 Roadrunner  383 4 spd
1965 Belvedere 413 long cross ram
1970 Dodge Superbee 440 6-pak
1970 Plymouth Superbird Ray Barton 426 Hemi
Offline cudabob496
Re: Electric fuel pump
« Reply #1 on: August 22, 2013 - 08:56:51 PM »
Seriously doubt it.  Unless maybe you gut the mechanical.
2011 Kawasaki Z1000
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #2 on: August 22, 2013 - 09:27:12 PM »
Quote
Yes, it will work that way.  I have three vehicles plumbed like that including my 70 Challenger.  I do find that in heavy throttle the mechanical pump does not keep up with the demand when pulling through the electric pump when it it is turned off.    When this happens I flip on the switch for the electric and all is good.
The Brewmaster
Offline CudamanTom
« Reply #3 on: August 22, 2013 - 10:11:14 PM »
Just curious, why don't you leave the electric fuel pump on?  :clueless:
I mean I wouldn't want failure during performing a heavy throttle.
Besides, I can't help but think an "off" electric fuel pump might restrict flow anyway. But that's just IMHO.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline cudabob496
« Reply #4 on: August 22, 2013 - 10:42:05 PM »
Oh, you want both working at same time? Dang, might
give you some seriously high fuel pressures.
Holleys only need 5 to 6.5 psi.
But, maybe you can plumb in a regulator somewhere.
How about running the mechanical, then if it quits, flip a switch, and the electric comes on?
2011 Kawasaki Z1000
  • Mopars forever!
« Reply #5 on: August 23, 2013 - 12:31:34 AM »
When purchasing your electric check the output pressure for compatibility with a carburater, which should be no more than about 7.5 psi.
The Brewmaster
