Author Topic: a/c question!  (Read 1407 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
a/c question!
« on: March 30, 2005 - 07:42:33 PM »
Hey I gotta a/c question I hooked up my a/c compresser today (put a belt on it) and the compresser turns freely nor smoke or noises but the cluth want engage is the cluth bad or do i need a new compresser?? thanks!  :beer:
My family, My cars, My guns three things il fight for!!
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: a/c question!
« Reply #1 on: March 30, 2005 - 08:26:15 PM »
Check to make sure there is 12 volts at the compressor.
It might not be getting voltage to the clutch.
If it is low on charge it will not engage the clutch.
There is a low pres. switch on the dryer.
Worlds first e-body trailer.    Severna Park, Maryland
Offline Mr. 6pak2go
Re: a/c question!
« Reply #2 on: March 31, 2005 - 07:46:29 PM »
thanks
Plum6Pak
Re: a/c question!
« Reply #3 on: March 31, 2005 - 08:04:16 PM »
You could also run a jumper to it and see if it engages without the engine running, it should pull in each time you make contact with the wire. If not, may have a bad winding. Hope you get it going!
Offline Mr. 6pak2go
Re: a/c question!
« Reply #4 on: April 01, 2005 - 06:52:27 PM »
il try that thanks man!!  :beer:
