Author Topic: 71 Cuda Conv Restoration  (Read 36609 times)
Offline mcemond
    • Cuda Build Photos on Flickr
Re: 71 Cuda Conv Restoration
« Reply #90 on: May 16, 2017 - 10:48:53 AM »
Here's some more pics. Its coming along.
Offline 340challconvert
  • A66- Challenger Registry
    • A66CHALLENGER.COM
« Reply #91 on: May 16, 2017 - 01:02:37 PM »
Michael
Hello from New Jersey
I just found your thread on the Y1 Cuda convertible restoration
NICE JOB
I just pulled my 70 A66 Y1 Challenger convertible out of storage since 1984 and started to finally work on it.
Your work is an inspiration.
1970 Challenger A66 Registry
Offline mcemond
« Reply #92 on: September 05, 2017 - 10:32:38 AM »
Looks like a nice project 340chalconvert, looking forward to seeing it all shined up :cheers:
Thought I'd post some updates. I feel better these days and I think its in part to forcing myself to get back into what I love doing... wrenching on cars.
I'm continuing to scour the area for parts and just found the 4973 carb I've been looking for at a pretty good price. Still trying to get a block with a closer assy/ cast date or a warranty block but that's just for fun to see how close I can get.
Unfortunately I took the convertible top to the *wrong* place for blasting and painting. Had to have them re-blast it to get all their paint drips off and now its at my friends place to get painted correctly. I won't name names because they did what I asked to correct the situation without argument.
Also the first guy that re-built the rear diff didn't fill the pits in the yoke so that came back out as it started leaking immediately. Odd note, the new guy I have rebuilding the diff for me is great but said he'd never seen a case like mine. Its a 741 case, which my books say was used on 71 340 e bodies although usually in non-performance cars, and he said usually they have a different pad with the date on them. Mine has a stamp on the rough cast side with the gear and the assembly date 10/29/70. So I thought that was kind of cool. We also worked out all the gearing in the front and rear so I get some good low end while still having a nice highway gear.
Sent the steering box out to firm feel. I was going to do a rebuild myself but they seemed to be able to be able to get a better result through the ball sizing and machining work they do. Did this so I can get the steering column in so we can get it on the trailer and take it to my friend's were he is going to spray the organosol and I also got the proper textured argent for the grill from Gibson restorations. Saw Cody's organosol video too and looked impressive so if the Gibson product doesn't look the part, my friend studied Cody's technique too.
Used the Year One bucket seat foam and covers and aside from the first foam set being ripped in half and glued back together, then waiting for months for a replacement from them, I found it pretty good. It was my first time doing upholstery and for a complete novice, it turned out ok. My fingers are destroyed,  but I'm happy with the result although a pro could have done better I'm sure. Because I'm short I actually stuck an extra 2" of foam in the base so the seat does poof up a little on the drivers side.
I also took a long time tackling the steering wheel. It was in the same shape as many I've seen. Grain and stain still present on parts while worn smooth to the tan plastic over 50% of it.  I've read several posts and articles on various techniques but I didn't want to sand down the wheel and loose the grain that wasn't worn away. I also discovered a past owner had engraved "Tricia" in the wheel, then tried to scrape it out  :dunno: Maybe a past love turned X? Anyway, I thought it was a great little part of the car's history and I wanted to keep it intact. I decided to use an xacto scalpel and cut each missing grain back into the surface of the wheel which actually only took one night while watching TV with the wife. Then I bought several different stains and sampled and mixed until I found a formula that matched the original stain color that still existed on the wheel. First I rubbed a thick dark ebony stain into the cuts I made and wiped off the excess. Then I went over the whole wheel with the lighter stain mixture I made up and was really happy with the results. To finish the process I clear coated the wheel with 4 coats. Small successes. Tried attaching photos and it didn't work I'll try again here...
Anyway, lots of parts are starting to find their way on to the car finally and we are moving at a better pace now. I'll post more in the next few weeks.
Offline mcemond
« Reply #93 on: September 05, 2017 - 10:39:03 AM »
pic 1
Offline mcemond
« Reply #94 on: September 05, 2017 - 10:39:57 AM »
pic 2
Offline mcemond
« Reply #95 on: September 05, 2017 - 10:40:38 AM »
pic 3
Offline mcemond
« Reply #96 on: September 05, 2017 - 10:42:05 AM »
pic 4
Offline mcemond
« Reply #97 on: September 05, 2017 - 10:43:59 AM »
pic... whatever number I'm no now...
Offline mcemond
« Reply #98 on: September 21, 2017 - 08:23:46 AM »
Hi. Can someone post a pic of the proper location of the door vin sticker on a 71 cuda convertible ?  Thanks. Mike
    • A66CHALLENGER.COM
« Reply #99 on: September 22, 2017 - 11:41:18 AM »
Looking forward to seeing your postings on your work.
Offline mcemond
« Reply #100 on: September 26, 2017 - 12:32:28 PM »
Thanks 340.
Still looking for a pic on an unrestored cuda or barracuda convertible showing the placement of the door vin sticker. I've seen pics of restored verts only and it shows it horizontal and 3-4" lower than those found on the hardtop. Is this correct?
Thanks
Offline larry4406
« Reply #101 on: September 29, 2017 - 07:16:45 AM »
Here are pics of my door VIN sticker from my 71 barracuda vert.  Unmolested original, I am 2nd owner.  Date on sticker is 12-70.
Hope this helps you.
Following your project!  I'm jealous.
Still looking forward to you posting the details and pictures of how the AMD hardtop quarters were modified to become vert quarters.
« Last Edit: September 29, 2017 - 07:29:42 AM by larry4406 »
Offline mcemond
« Reply #102 on: September 29, 2017 - 07:49:57 AM »
Thanks Larry. That's perfect! Sorry about not posting those pics. I'll do it now...
Offline mcemond
« Reply #103 on: September 29, 2017 - 08:10:53 AM »
Here's the first one showing the cut and the screws holding it to the inner using the existing trim mounting holes. Here he has started the bead along the top edge...
Offline mcemond
« Reply #104 on: September 29, 2017 - 08:12:05 AM »
Here is the other side showing it with the bead more complete and adjoining sheet metal...
More to come. My computer has no choke pull so it takes a little while to warm up :)
« Last Edit: September 29, 2017 - 08:13:52 AM by mcemond »
