Author Topic: license plate light install help  (Read 592 times)
Offline IndyCuda
« on: August 27, 2013 - 05:50:53 PM »
I have a '72 Barracuda currently without a plate light. I bought the housing and lens off flea bay. When I went to install it there was a single black wire there. I went and bought a single wire housing for it and a new bulb. The tail lights worked fine but the plate light was still not working. Is the plate light supposed to be a 2 wire , one power and grounded? If it is a single i can't check to see if it is getting power...dead ...I mean dead battery right now.
Offline Jamiez
  • Retro
Re: license plate light install help
« Reply #1 on: August 27, 2013 - 06:01:28 PM »
There are no ground wires in that harness, everything just uses body grounds.
« Reply #2 on: August 27, 2013 - 11:12:06 PM »
 :iagree: it will be a single wire grounding back through the body
Offline Jamiez
  • Retro
« Reply #3 on: August 28, 2013 - 06:21:54 AM »
For reference this is the harness:
1   - Connector located behind kick panel
2   - Fuel tank sending unit
3   - Dome light
4   - License plate light
5   - Passenger side reverse light
6   - Driver's side brake light
7   - Driver's side reverse
8   - Passenger side brake light
9   - Passenger side side marker
10 - Driver's side side marker
