Author Topic: billet rear servo  (Read 990 times)
Offline black71
  • eph 6:12
billet rear servo
« on: August 28, 2013 - 02:16:21 PM »
install a tf3 kit to run my six pack w/o any kickdown... figured i'd throw in a billet servo while the pan is off... which one to get.. are these any good?
http://www.ebay.com/itm/250987436831?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Offline 6packCuda
Re: billet rear servo
« Reply #1 on: August 30, 2013 - 09:04:31 PM »
Yes, that servo piston would be a huge improvement over the stock one. However, the kickdown linkage is still functional with the tf3 kit. You either need to hook up the kickdown linkage or wire the lever all the way back. If the car is driven a lot, hooking up the linkage is the better option because the constant high pressure is hard on seals.
« Last Edit: August 30, 2013 - 09:13:31 PM by 6packCuda »
Offline black71
  • eph 6:12
« Reply #3 on: September 04, 2013 - 08:46:07 PM »
Thanks, i think randys are what most of the f.a.s.t. guys run
