there are 2 tri plugs in that area specifically for that , they use a bullet connector yellow is constant power & red is switched power or you can plug into the radio plug which has a red & orange wire , red will be switched & orange is for the factory lighting , I wouldl connect the red wire to the factory radio plug & the constant power tot he yellow tri plug
