Author Topic: oil pressure light stays on  (Read 930 times)
Offline IndyCuda
« on: August 28, 2013 - 04:12:35 PM »
72 Barracuda auto 340. Engine was rebuilt less than 500 miles ago. The sending unit is as new. The oil light stays on. I checked my connection and it is tight. The wiring harness is new from Bill Evans and I don't think it is grounding out.  Checked the level and it looks about a half quart high. Is slightly too much oil enough to trigger that. Should I drain a little out?
Re: oil pressure light stays on
« Reply #1 on: August 28, 2013 - 04:19:13 PM »
Can you put as mechanical gauge on it to see what the oil pressure really is?
Offline CudamanTom
« Reply #2 on: August 28, 2013 - 05:15:19 PM »
It might be a problem with the mechanical pump or oil pickup tube. 500 miles is enough for anything to work lose or break if it's going to fail.
For sure do as Brad suggests.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #3 on: August 28, 2013 - 07:42:09 PM »
If your really have really low oil pressure your lifters should be very  noisy.
The Brewmaster
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: August 28, 2013 - 07:46:50 PM »
Definitely get a gauge on there and verify what the true pressure is!    :grinyes:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: August 28, 2013 - 08:45:04 PM »
 :iagree:  Like everyone said, get another gauge on there to verify the pressure.
Why is the level high?  Does it smell like fuel or antifreeze?  Does it feel thinned down between your fingers?
Reason why I ask is that once my oil pressure dropped so I check the level and it was almost a quart over and smelled like gas.  Turns out my carb was dumping gas into the intake and thinning out the oil, thus the drop in oil pressure and higher oil level.  :2cents:
« Reply #6 on: August 28, 2013 - 10:41:42 PM »
Did you buy the correct new sending unit?.. The one for the rallye gauges would provide a continuous ground while the one for the light would be open under pressure
