Author Topic: Ignition Key Barrell won't turn. Rattle in steering column. Related?  (Read 605 times)
Offline cudaracer
There has been a rattle in my 72 steering column that was slowly getting worst.  It's proximity appears right near the key ignition.  Now, I can barely turn the key, only after jiggling it and the wheel again and again until it finally works.
Are these related?
I am about to dig into the steering column.  Any tips or suggestions.  The key ignition barrel is cheap.  Not sure what else can be rattling down in there.
Thanks
Re: Ignition Key Barrell won't turn. Rattle in steering column. Related?
« Reply #1 on: August 28, 2013 - 10:58:10 PM »
Hard to say if it is related , sounds like the key is worn or the cap holding the springs has let go so the pins are not pushed down on the pins in the lock
Offline cudaracer
« Reply #2 on: August 29, 2013 - 10:35:39 PM »
Thanks.
Is it best to take the whole column out to repair it?
Offline Rich G
« Reply #3 on: August 31, 2013 - 11:47:49 AM »
I would take the wheel and hub off first. You'll probably see whats wrong once its off. Why go through the extra work if you don't have to.
