Author Topic: power steering pump pulleys?  (Read 4134 times)
Offline CUDA JAS
  • vroooooom!
« on: August 28, 2013 - 10:37:22 PM »
What is the difference in power steering pump pulleys...Ihave seen the 3 spoke pulleys and solid pulleys???
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline HP_Cuda
  • Mopar or No Car!
Re: power steering pump pulleys?
« Reply #1 on: August 29, 2013 - 12:05:12 PM »
I can tell you that the solid ones are for small blocks while the 3 spoke are for big blocks.
Apparently the 3 spoke are larger for big blocks so they can turn slower, whereas I believe the solid ones are 1 for 1 or close to it.
Offline BIGSHCLUNK
« Reply #2 on: August 29, 2013 - 12:06:01 PM »
Beware of different offsets!  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: August 29, 2013 - 07:05:29 PM »
Good point as that bit me already!
 :wow:
Offline BIGSHCLUNK
« Reply #4 on: August 29, 2013 - 08:11:34 PM »
 :grinyes:  been there done that!    :banghead:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: August 30, 2013 - 02:23:36 PM »
Interesting....how do you tell the diffence and or what offset you need??
Jason
74 'cuda 360/727
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: August 31, 2013 - 02:14:39 PM »
JAS
It depends on your setup.
Do you run power steering and A/C?
If you are running only power steering and an alternator with the ever present water pump on a 440 then take a look at 440source as they have the correct one with proper offset. It's the one I am using now and didn't take much to set it up.
B
Offline BIGSHCLUNK
« Reply #7 on: August 31, 2013 - 10:23:38 PM »
I got a pulley for my HEMI from buchillion, they got others also
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline jordan
« Reply #8 on: September 01, 2013 - 01:44:55 AM »
I got my PS pump from Buchillion too.  The dude there really knows his stuff.  Sent me a complete setup......pump, reservoir, cap, bracket, hardware, pulley, and pressure line.  The brackets are nice and thick and powder coated.  Everything lined up.  You just have to press the pulley onto the pump shaft.  Easy enough.  The price was reasonable too, but it all adds up to $$$$
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: September 13, 2013 - 09:29:08 AM »
JAS
B
I am planning to run powere steerign and alternator only, NO AC.
I have a pump and brackets (well most of them).  The pulley is the solid.  I think i have seen that hte solid pullyes are for big block and the 3 spoke pulleys are for small blocks.  Just want to make sure I have the right parts beforr I get any further.
Jason
74 'cuda 360/727
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: September 13, 2013 - 01:02:39 PM »
If you are running a big block with power steering and an alternator and NO A/C you need this:
http://store.440source.com/Power-Steering-Pulley-Fits-Saginaw-w_Key-New-Reproduction/productinfo/132-1003/
Offline CUDA JAS
  • vroooooom!
« Reply #11 on: September 13, 2013 - 01:18:25 PM »
srry..running a small block.
74 'cuda 360/727
Offline YYZ
« Reply #12 on: September 13, 2013 - 02:19:52 PM »
If someone could post detailed pics of the small-block setup please, it would be appreciated.  I provided CUDAJAS with a '70 340 pump (Saginaw) which may still be missing a bracket and we need to know what to look for (I have lots o' brackets...)
Thanks in advance
Offline 73EStroker
« Reply #13 on: September 17, 2013 - 02:07:06 PM »
I have the factory setup off my original 340  - brackets and the right pulley if you need them let me know because you are in Canada no? I am so that means no getting screwed for customs $$$ if you are north of 49.
Barry (Salmon Arm)
Offline tman
« Reply #14 on: May 21, 2015 - 04:29:42 AM »
I know this is an old post but it sure answered my question.  My PS pulley is a bit wobbly and was looking for replacement.  Was concerned about offset too.  But for a 440 running Alt, PS, and WP, no a/c, the pulley from 440 Source is the way to go.
Now, is removing the nut is all that is needed to remove the pulley or do I need a puller also?
Thanks
