Author Topic: Bracket help???  (Read 979 times)
Offline jmartin99
Bracket help???
« on: August 29, 2013 - 03:41:50 PM »
I am putting together a '72 Challenger 340 with A/C. The picture below has two brackets. Is the slotted bracket the correct lower bracket for the Alternator on my engine setup?
What does the other bracket go to?  :clueless:
Thanks!
Jeff
Offline 4Cruizn
  • HEMI FISH
Re: Bracket help???
« Reply #1 on: August 29, 2013 - 03:46:49 PM »
I would say they are both the alternator brackets.   :clueless:
Offline anlauto
Re: Bracket help???
« Reply #2 on: August 29, 2013 - 03:48:15 PM »
I would GUESS the "V" shaped bracket is for the power steering. The alternator bracket looks to be for a non-A/C application in my opinion.
Offline 4Cruizn
  • HEMI FISH
Re: Bracket help???
« Reply #3 on: August 29, 2013 - 03:53:43 PM »
This may help . . .
Offline anlauto
Re: Bracket help???
« Reply #4 on: August 29, 2013 - 03:58:32 PM »
Your picture (above) doesn't have A/C which makes a major difference.
Pictured below is the correct lower bracket for a 340 alternator with A/C. it mounts with the engine mount on the block.
Offline anlauto
Re: Bracket help???
« Reply #5 on: August 29, 2013 - 04:06:59 PM »
These are the correct power steering brackets for a 72 340 with a Saginaw pump. Your "V" shaped bracket looks similar to the one in the center of the picture, but not 100% correct.
