Author Topic: QA1 K Member  (Read 6433 times)
Offline GreenFish
QA1 K Member
« on: August 29, 2013 - 07:19:16 PM »
Thoughts?  is it worth the cash?
Looks like is a swap. Use torsion bars and the stock steering.
http://www.qa1.net/qa1_motorsports/drag-and-street/suspension-components/k-members/mopar-k-members.html
$700
Other similar option is Firm Feel will beef up your old K member for $450 + 150 to powder coat it then you have to ship it. So that's over $600 and you still have the same old K member. For $100 more you get a newly engineered piece that is lighter than stock and probably stiffer. You could probably find free shipping for the new piece too.
« Last Edit: August 29, 2013 - 07:25:01 PM by GreenFish »
Re: QA1 K Member
« Reply #1 on: August 29, 2013 - 08:54:27 PM »
Of course the furd on eis less than 1/2 the price of the Mopar part  :banghead:
Offline GreenFish
Re: QA1 K Member
« Reply #2 on: August 29, 2013 - 09:15:20 PM »
of course, it wouldnt be mopar stuff if it wasnt more expensive.
Re: QA1 K Member
« Reply #3 on: August 29, 2013 - 09:40:00 PM »
Me? I'll stick to the beefed up stock one. Do you have access to a welder? It would cost next to nothing to do it yourself?
Did you see this one from MF yet?
Magnum Force Modular Transformer Mopar Suspension
Looks too heavy to me?
Offline moprr
Re: QA1 K Member
« Reply #4 on: August 29, 2013 - 10:19:37 PM »
Their website says it knocks off nearly 100 lbs from a stock setup?
Offline GreenFish
Re: QA1 K Member
« Reply #5 on: August 30, 2013 - 07:22:56 AM »
MF stuff is sweet but waaay outside the realm of price that we are talking.
I think the QA1 is a nice affordable option that is somewhere between stock and RMS Alterkation, The XV and MF stuff takes it to a new level.
Re: QA1 K Member
« Reply #6 on: August 30, 2013 - 09:36:04 AM »
IIRC, the QA1 piece is only about 30-40# less weight than the stock K. This is because they had to add so much more structure back into it to maintain its rigidity. It will utilize all OEM parts such as control arms, steering box, brakes, and T-bars so if you have good pieces there, it will minimize your cost of conversion. However, if you chose to go full tilt with all their tubular components, new rate T-bars, bigger binders, and a Borgeson steering box, it will cost about $1200 less than a comparably equipped AlterK.
The original QA1/CAPP tubular frame may have been 100# less than stock once built out. Of course, they also had rigidity issues with it and weld failures on their control arms. I believe AlterK is also claiming a 100# reduction with their unit.
The nice think about the QA1 vs AlterK set up is you really could modify in stages using their parts. With an AlterK, you have to swap out the whole thing all at once to utilize it. That's a $4500 hit to the checking account all at once.
The Magnum Force unit is all chrome-moly steel, so while it appears huge in comparison, they are claiming the entire set up is 20# less than stock. Personally, I think most of that weight loss is in the brake system. They list it for $5000, so it is about $500 more than a fully speced AlterK unit.
Offline GreenFish
Re: QA1 K Member
« Reply #7 on: August 30, 2013 - 10:51:08 AM »
I agree that the QA1 helps the guy who can only afford to build in stages. Most folks don't have 4K+ to drop all at once.  But I can throw a bit at a time and build up.  That MF unit looks trick! but I'm not sure I can afford that kind of stuff. The QA1 maybe in my future.
Offline ajantics
    • Yeah......Im a drummer!
Re: QA1 K Member
« Reply #8 on: August 30, 2013 - 12:30:27 PM »
Did QA1 buy out CAP Auto products? I have a CAP k frame and it is at lest 10 pounds lighter then the stock k frame. But like most cap products I have had weld failures. Lucky for me I have had very little miles on the car and was able to fix them before something horrible happened. I hope QA1 would fine tune this design and have it manufactuerd with higher standards than my CAP k frame. My buddy and I are currently building a jig to build our own based on the RMS k frame to replace my Cap auto one.
« Last Edit: August 30, 2013 - 04:22:18 PM by ajantics »
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Re: QA1 K Member
« Reply #9 on: August 30, 2013 - 02:40:39 PM »
Did QA1 buy out CAP Auto products? I have a CAP k frame and it is at least 100 pounds lighter then the stock k frame. But like most cap products I have had weld failures. Lucky for me I have had very little miles on the car and was able to fix them before something horrible happened. I hope QA1 would fine tune this design and have it manufactuerd with higher standards than my CAP k frame. My buddy and I are currently building a jig to build our own based on the RMS k frame to replace my Cap auto one.
Yep QA1 bought them out. How can the K-Frame me 100lbs lighter when it doesn't even weight 100 lbs? You must mean when everything is assembled on the k-frame?
Offline ajantics
Re: QA1 K Member
« Reply #10 on: August 30, 2013 - 04:23:34 PM »
Sorry Brad! That was a typo lol! I typed to fast and added an extra 0. It is at lest 10 pounds lighter.  :cheers:
70 Barracuda
73 'Cuda
2009 G37s
Re: QA1 K Member
« Reply #11 on: August 30, 2013 - 05:30:57 PM »
Ah!  :crazy:  that makes more sense!  :2thumbs:   Why would you spend all that time and money for the sake of 10 lbs then? Clearance for headers or something?   :dunno:   Also I'm leery of there design? I know I would touch Cap Auto stuff with a 10 foot pole from the horror stories I've read?
« Last Edit: August 30, 2013 - 05:32:36 PM by brads70 »
Offline cudagirl4406pk
    • Garageartmusclecars
Re: QA1 K Member
« Reply #12 on: August 31, 2013 - 07:40:38 AM »
Hey JOe kenny can weld up that k member for you if you want to make it stronger send me a PM i give you his number.He still Has his chamelon GTO also and my orange cuda and 3 other cars maybe you stop up the shop and see all the toys and projects he is doing for people.
michele
Offline GreenFish
Re: QA1 K Member
« Reply #13 on: September 06, 2013 - 11:56:53 AM »
So my understanding is that QA1 bought out CAP as stated. However they re-engineered the Kmember and control arms. I've heard horrible thing about CAP. IF you remember the CAP stuff stated that it was for race only and not recommended for street use.  That's because it wasnt strong enough to handle the twists of turns.
