Author Topic: Copper Header Gaskets causing Backfire - Help!  (Read 725 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« on: August 29, 2013 - 11:47:40 PM »
So I replaced my '71 Challlenger (360) header gaskets with copper gaskets, tighten the new Stage 8 bolts down following the head gasket pattern, no RTV, and when I fired her up lots of backfiring and ticking on both sides. I know I have to do a heat cycle which I let the temp get up to about 190 before shutting her off to cool down. Tell me this is going to get a lot better when I tighten the bolts again in the morning, or did I seriously mess something up.
Offline HP_Cuda
  • Mopar or No Car!
Re: Copper Header Gaskets causing Backfire - Help!
« Reply #1 on: August 30, 2013 - 02:49:46 AM »
It will take 2 or 3 cycles to get them to seat in the final position.
Stick with it - it does get better.
