Author Topic: Question about Idle solenoid  (Read 787 times)
Offline Nel
« on: September 01, 2013 - 04:50:33 PM »
Hi
Just install and set a new carb AVS 4933S on my 340 and I was looking in the service manual how to set the Idle solenoid. I think that I'm missing something, in the fig. 23 they show a Distributor ground switch lead (I circle it in red). I can see on the braket that there is a place for that but just dont have it. Then I look in the electrical diagram to see where its suppose to connected and I dont see it. What that part for? Can somebody shown me where its suppose to connect.
Also, I'm not sure if I understand (instruction in yellow) how to adjust the Idle solenoid. I have to turn the screw circle in green until the engine is at 950 r.p.m, then turn the same screw so it just touch the end of the solenoid and unscrew a full turn?
Help Please
Offline Strawdawg
    • Vortex Buicks
Re: Question about Idle solenoid
« Reply #1 on: September 10, 2013 - 11:55:04 AM »
I have not seen one of these in about 40 years so I am going to speak in generalities and maybe it will help you.
Electrically, I see what you are talking about on the distributor ground lead, but, I am pretty sure this is not used and the ground is made thru the carburetor and it's attachment to the intake.  Power is fed from a switched ignition source that energizes the solenoid when the key is ON.
It's easy enuf to test that...ground the case and apply power to the lead coming out of the solenoid.  Plunger should jump out a little.
On the set up, crank the engine up, warm it up, and then set the idle by adjusting the screw that touches, or should touch, the end of the solenoid plunger until you get to 950 rpm.
Now, the screw they refer to as the curb idle screw...they say to adjust it until it touches the Throttle Body and then back off one turn.  I believe that screw is on the opposite side of the carb where the throttle linkage from the accelerator pedal is attached (what normally would be the idle adjusting screw).  Turn it until it makes contact.  At this point, if you turn it further, the idle would increase beyond the 950 rpm that you set at the solenoid plunger....instead, you back it off one turn(this does not affect the idle because you set it at the plunger).
Now, when you turn the key off, the plunger retracts and the screw that you backed off one turn now becomes the idle speed screw and allows the throttle blades to close a bit further cutting off most of the air to engine and preventing after run or dieseling.
The book's instructions are very unclear.  I hope mine are right  :D  I remember that was how most cars worked.
Offline Nel
« Reply #2 on: September 15, 2013 - 09:23:56 PM »
Cool I will try that next time my working on the car
Thank you
