Author Topic: Lost wheel on highway  (Read 21734 times)
Offline BIGSHCLUNK
Re: Lost wheel on highway
« Reply #15 on: September 04, 2013 - 09:11:06 PM »
These are good thoughts here. I strongly advise you to check the other side. I Also agree that it wouldn't last 2 years (under normal conditions). Now I put on 1000-1200 miles a year..................................................................... even so improperly torqued bearings can HEAT UP very quickly  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #16 on: September 04, 2013 - 09:30:33 PM »
Looks like this kit?
http://www.classicindustries.com/1970/mopar/parts/a156.html
Those rotors with the cutouts always scared me?( same style on vintage Mustangs) Looks like it broke the center out of the rotor. If it was a solid rotor maybe the wheel wouldn't have broke off and the rotor/caliper would have held the wheel on till you could pull over?
« Last Edit: September 04, 2013 - 09:41:16 PM by brads70 »
« Reply #17 on: September 04, 2013 - 09:38:12 PM »
The retaining nut was tightened but not backed off for bearing  tolerance. Free spin.
Picture shows retaining nut and washer melted to nut. Bearings disintegrated.
:iagree: Looks melted to me.
Offline BIGSHCLUNK
« Reply #18 on: September 04, 2013 - 09:50:53 PM »
I've seen rotors break of hubs before ( when they were really thin) but never lost a hub off the spindle.......  :clueless:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #19 on: September 04, 2013 - 10:10:22 PM »
Same here, at the race track. China crap would break, but the wheel wouldn't come off the caliper would hold it on. North American rotors seemed to be fine. I even noticed a difference machining them for bigger studs, the China crap would flake off and the North Americans would produce a good chip.
 The one here looks to have blown apart, no rotor left?
Offline BIGSHCLUNK
« Reply #20 on: September 04, 2013 - 11:08:35 PM »
Brad, Same here per your race track analogy. I'm really curious as to what the other side looks like, it may present the answer or at least a good clue.  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Padawan
  • Noob!
« Reply #21 on: September 04, 2013 - 11:53:57 PM »
Wow, lots of insight here, and thanks everyone for the concerns!
The car is currently 50 miles away as I had to get back home to work the same evening. I'll properly inspect the other side when I get it back home to my preferred shop, I guess that should clear up whether the retaining washer was left out, ball bearings were used or the nut was over-tightened.
@blown motor
A wrongly tightened nut sounds plausible to me, and that's what the mechanic's first instinct was as well. I put a little over 2,000 miles on the car in 2 years, not sure how many mile the previous owner put on after putting in disk brakes.
@anlauto
I don't have any radio in, it was only the motor we were listening to! We drove down from Maine over some curvy routes (route 3) and then onto I 93, but just smooth sailing. The brakes felt a little weird at a toll station a couple miles up as I remember now, then on the highway I think I told my buddy I heard something once or twice, before I definitely heard a clunk that made me start to pull over, right before the wheel decided to have its own way.
@AARuFAST
Boah, nice input with the fender. The mechanic gave me a blank stare when I asked him about fixing the fender, I hope he doesn't do more damage to it when bending it so the wheel will fit. For the alignment, I had new wheels and always a slight left-pull, so this sounded to be the perfect opportunity. However the guy suggested to replace the left-side pitman arm first (because it was loose), but said it's still okay to drive around, just something to do rather sooner than later. He called me today that the part had arrived...
@brads70
That should be the kit, exactly! Haven't recovered the rotor, only what's in the images.
I'll keep you guys posted, thanks for all the thoughts!
1970 Challenger RT/SE 383
Add yourself here and then find others on the map
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #22 on: September 05, 2013 - 12:10:02 AM »
absolutely nuts that this happened
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline HP_Cuda
  • Mopar or No Car!
« Reply #23 on: September 05, 2013 - 02:45:35 AM »
Definitely want to back off the retaining nut (wheel turns freely) so the bearings don't self destruct which it looks like here.
 :bricks1:
« Reply #24 on: September 05, 2013 - 07:35:36 AM »
Your going to need a spindle as that one will be scrap.  If this were my car I'd put  E-Body disc brake spindles on it now to avoid those rotors ( but that's just me)
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #25 on: September 05, 2013 - 08:16:54 AM »
 :22yikes:  Wholly crappers, Padawan!  Thank God no one was hurt!
I just kept staring at those pics (But not as long as the Stonehenge pic Bigs' dog made.  :rofl: ) and couldn't believe what had happened!
Hope it all gets sorted out.  Are you bringing it to Jimmy to work on?  Do you have AAA?  Let me know if you need a ride or help.  :thumbsup:
Offline BIGSHCLUNK
« Reply #26 on: September 05, 2013 - 09:17:47 AM »
 :roflsmiley:  :smilielol:  :roflsmiley:  :smilielol:  :roflsmiley:  :smilielol:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #27 on: September 05, 2013 - 10:25:53 AM »
...or maybe the tire came off the rotor and the rotor skidding along the asphalt caused the components to disintegrate and fly all over the place and the "after" pictures we're seeing is all the recovered pieces that are left.
The opinion below sounds like the most likely candidate for what happened.
This is not that schocking. I farm and I've seen it more than once. If the nut is not tensioned properly when it's install the bearing won't last nearly as long as it should. Almost certainly it was a taper roller bearing. If the pressure (tightness of nut)isn't right then in time the rollers will chew up the cage that holds them in place and eveything comes undone. Last fall i had a wagon wheel come off on the road and go through a fence and 75 yards into a field. The number of times I've seen it on farm equipment makes me wonder why we don't see it more with cars.
Offline ragtopdodge
« Reply #28 on: September 05, 2013 - 04:31:49 PM »
So weird it wasnt noisy before it blew.
Ya, pretty basic, but need to torque down the nut, and back off a quarter turn.  Maybe also not enough grease?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline CudamanTom
« Reply #29 on: September 05, 2013 - 06:17:11 PM »
What gets me is the rotor coming off while getting past the disc brake caliper and not breaking/ripping it off in the process. Unless.....
The rotor shattered in the process when things were getting hot/damaged. Dunno  :clueless:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
