Author Topic: Big Sway Bars ???  (Read 5809 times)
Re: Big Sway Bars ???
« Reply #30 on: September 23, 2013 - 08:48:04 AM »
yours is correct Jordan , the 4 U bolts still hold the diff centered in the shock plate
Offline jordan
« Reply #31 on: September 25, 2013 - 07:36:17 PM »
Hey Alan, this is what I got done.  The rear diff and axles should be ready tomorrow.  Brakes are loaded and ready to go.  Gas tank goes in tonight.  I can order the drive shaft as soon as the diff is in.  That should button up the rear.  Getting closer!
« Reply #32 on: September 25, 2013 - 08:43:06 PM »
Looks good! FYI, check clearance on the rear offset shackle around the bumperet bracket. I had to mill mine down a bit so it didn't hit. Might be a Challenger thing though IDK? :dunno:
Offline jordan
« Reply #33 on: September 26, 2013 - 12:19:59 AM »
Hey Brad, I did a little checking when I put them in, and didnt notice anything, but I will look again to make sure.  I did hold my rear valance in place to see if there would be any clearance issues, and I didnt see any there either.  Thanks for the heads up.   J
