Author Topic: 1971 340  (Read 3554 times)
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
Re: 1971 340
« Reply #15 on: November 02, 2013 - 02:59:38 PM »
Offline shoooter
Re: 1971 340
« Reply #16 on: November 03, 2013 - 12:03:00 AM »
http://sacramento.craigslist.org/pts/4161374665.html
thanks contacted the owner its build date was 1/18/71 vin stamp was 1B349187 incase it is someone's
Offline LEMOOREACE
Re: 1971 340
« Reply #17 on: November 03, 2013 - 09:50:27 PM »
I actually have this block saved in my garage..  supposedly .030 over...  have no history on it.
Date 6-17-71
2780930
2G16469
2780930 340 LA 1968-73 Not T/A or AAR
« Last Edit: November 03, 2013 - 10:13:13 PM by LEMOOREACE »
Offline shoooter
Re: 1971 340
« Reply #18 on: November 04, 2013 - 12:16:09 AM »
How we are talking. That block was build 11 days before my car!
Offline LEMOOREACE
Re: 1971 340
« Reply #19 on: November 04, 2013 - 12:17:56 AM »
I've been sittin on it because I don't know if I wanna give it up...     :clueless:
Offline shoooter
Re: 1971 340
« Reply #20 on: November 04, 2013 - 12:20:41 AM »
well keep me in mind if you do
Offline LEMOOREACE
Re: 1971 340
« Reply #21 on: November 04, 2013 - 12:28:48 AM »
Is your car an original 340 car?
Offline Cuda Cody
  • Vancouver, WA
Re: 1971 340
« Reply #22 on: November 04, 2013 - 12:32:20 AM »
FYI, this is a 1972 model year block.
Date 6-17-71
2780930
2G16469
Offline LEMOOREACE
Re: 1971 340
« Reply #23 on: November 04, 2013 - 12:49:48 AM »
How does one figure that out Cody?
Offline anlauto
Re: 1971 340
« Reply #24 on: November 04, 2013 - 06:50:19 AM »
Pretty simple..It's casted in June of 1971, and the serial number tells the story "2G16469"...the "2" stands for 1972.
Offline shoooter
Re: 1971 340
« Reply #25 on: November 04, 2013 - 08:42:30 AM »
yes my car is a 340 car. So what would th3 proper cast date be for me cody?
Offline anlauto
Re: 1971 340
« Reply #26 on: November 04, 2013 - 09:01:34 AM »
The assembly date could be within three months typically of your build date. What you want to check is the assembly date of the block which is stamped on the front driver's side below the cylinder head.
The casting date could be anytime before your car, even up to a year (not typical)
Also if you're looking for blocks always check the VIN. In your case it should start with a "1B" if it does then you know it even came from the same assembly plant as your car, then obiviously the rest of the VIN will indicate whether or not it was made before or after your car.
Offline LEMOOREACE
Re: 1971 340
« Reply #27 on: November 04, 2013 - 11:04:27 PM »
« Last Edit: November 04, 2013 - 11:18:30 PM by LEMOOREACE »
