Author Topic: Tyler's leftovers in DFW  (Read 4074 times)
Offline miketyler
    • www.miketyler.net
« on: September 08, 2013 - 12:13:34 PM »
My 72 Cuda restomod is done and I have quite a few parts leftover. All located near DFW Texas
Set of OEM power window switches, 6 pcs total; 5 singles and one 4switch master. Can be used with Electric Life regulators asking $175obo
pair of rear bumperettes with brackets $100 obo
pair 340 water pumps, one six blade, one 8 blade both for $25 obo
Custom billet dual-groove water pump pulley for 340 $50
Ashtray (in dash) $20
Fuel line and brake lines $10
Lokar Hi-Tech stainless throttle cable TC-1000HT (new sealed) $40
Pair of original "'Cuda 340" emblems great shape $25ea
Cam plate for 340 318 360  OEM $20obo
fender turn signal parts $25obo
low fuel relay for console car unknown condition, assume non working $25
2 pair of "Plymouth" gravel guards one cracked, take all 4 for $20
340 oil pump and timing gears low time, replaced all during rebuild $20
Assorted chrome brackets, alt, heater hose, etc $35
Door handles, one complete, one housing with springs all for $25
Mopar air selector vacuum hose and fitting not for Cuda  free with any other parts purchased
Pair Carter Thermoquads  correct 6139s for 72 Cuda V8. Both rebuilt, one done by Demon Sizzler, never run. The other rebuilder is unknown. Asking $150ea
rear spring brackets for 72 Cuda, a little surface rust but till clean up with bolts OEM, $25
OEM U-bolts for rear end $10
rear radio support hanger, powercoated satin black, $20
Speaker fader control plug and wiring $20
Edelbrock 1406 carb, low run time could use cleaning. $175 obo
Pics coming after I reduce them. Until then best to email me at tyler_mike@sbcglobal.net
« Last Edit: December 16, 2013 - 06:47:27 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline brotow
  • There really is a Challenger in the backround
Re: Tyler's leftovers in DFW
« Reply #1 on: September 08, 2013 - 09:32:17 PM »
Tell me more about the brake lines.  Will they fit a 70 challenger?  What have you got available?   pm sent
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline miketyler
    • www.miketyler.net
« Reply #2 on: September 09, 2013 - 12:56:28 PM »
I should have been more clear in my description. The lines are actually the short metal lines that connect to the master cylinder.
72' Cuda restomod
70 Mustang Mach 1
Offline brotow
« Reply #3 on: September 09, 2013 - 06:01:27 PM »
Ok thanks for the clarification.  Those lines I do have.  Thanks
Offline loco340cuda
« Reply #4 on: September 16, 2013 - 10:45:12 PM »
Do you have any picts of the "'Cuda 340" emblems?
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
« Reply #5 on: September 16, 2013 - 11:08:25 PM »
Does the speaker fader switch have 2 pots or one?
One potentiometer type are 3 speaker switch
two potentiometer type were for 5 speakers.
Offline Jamiez
  • Retro
« Reply #6 on: September 17, 2013 - 06:41:45 AM »
The stereo speaker one (used in 5 speaker cars) also has the 6 connection plug close to the fader.  The mono one (used in 2 speaker cars) has a longer wiring connector that runs to the driver's kick panel.
A 3 speaker car would have no fader, as that would be a stereo without any rears.
Offline miketyler
    • www.miketyler.net
« Reply #7 on: September 17, 2013 - 08:22:41 PM »
Sorry, this is the fader plug and harness only
72' Cuda restomod
70 Mustang Mach 1
Offline Katfish
  • 70 Challenger
« Reply #8 on: September 17, 2013 - 09:27:41 PM »
Tell me more about the fuel lines.  Will they fit a 70 challenger?  What have you got available?
Offline miketyler
    • www.miketyler.net
« Reply #9 on: September 18, 2013 - 08:03:28 PM »
I believe this to be the short metal line that goes to the carb. If you need main lines I would buy some annealed stainless and bend up my own. I did this on my other car and has worked out great.
72' Cuda restomod
70 Mustang Mach 1
Offline Katfish
  • 70 Challenger
« Reply #10 on: September 18, 2013 - 08:55:38 PM »
Yeah looking for the main line; thx
Offline miketyler
    • www.miketyler.net
« Reply #11 on: October 21, 2013 - 10:48:04 AM »
Some parts sold...others still available
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #12 on: October 21, 2013 - 10:51:35 AM »
Also have 2.5" stainless Pypes X assembly and other stainless exhaust hardware for sale in DFW for $250.
http://dallas.craigslist.org/sdf/pts/4126148847.html
« Last Edit: November 17, 2013 - 08:18:32 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline cuda346pk
« Reply #13 on: October 25, 2013 - 11:26:23 AM »
What fender turn signal parts do you have?
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
Offline miketyler
    • www.miketyler.net
« Reply #14 on: October 25, 2013 - 11:37:07 AM »
Assorted. Pair of housings, a pigtail, two lenses, some hardware. Let me post up a pic when I get home for you
72' Cuda restomod
70 Mustang Mach 1
