Author Topic: Any flooring guru's here?  (Read 1092 times)
Offline BIGSHCLUNK
« on: September 08, 2013 - 10:40:26 PM »
Seems I need to tap the talent pool here once again.  Its time to FINALLY do the kitchen floor. Seems like I'm able to knock off the old linoleum pretty easily. But there is some sort of (felt??) underlayment that's a sonofagun. Whats the best way to get this stuff off and not destroy the wood underneath??   -Hardwood not plywood
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline jimynick
Re: Any flooring guru's here?
« Reply #1 on: September 08, 2013 - 11:02:49 PM »
Well, I've done some of this and there's no easy way that I know of. Richards makes a nice 4" angled head scraper with a 12' handle and it's scrape-city. Since you're flooring over it, I don't see why you'd try to be overly careful and a carefully sharpened ice scraper- you know, the one's with a 4 ft handle, work reasonably well. Any way you cut it, it's an ugly job. Lots of guys use the 3/16" luan plywood and go right over the whole shebang. Just my  :2cents:
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #2 on: September 09, 2013 - 01:04:15 AM »
Nailed it right on the head.
Done this many times to remove the black underlayment.
The hand scraper is the way to go.
Electric styles don't work as well.  And they cause far more severe damage to the sub floor.
Lots of guys use the 3/8 plywood.  But I don't recommend it for most cases.
What flooring are you putting down over the top of the sub floor?
I personally usually scrape everything and then sand/ refinish the existing flooring.
Hope my two cents helped a little.
Offline CHL2T
  • Handle it, man!
« Reply #3 on: September 09, 2013 - 01:44:53 AM »
Use a heat gun to soften up the glue before scraping an interminable amount of time.....
Or as others have suggested, go over it with plywood, I normally use 1/4 sanded plywood underlayment shot down with 1" narrow crown staples
« Reply #4 on: September 09, 2013 - 07:30:00 AM »
I've used the as mentioned ice scraper method. Not a fun/ easy job.  :grinno:
Never seen that " felt" stuff before though? ( not that I've done a lot of flooring work either?) Are we sure that is not asbestos ? :dunno:
Offline 71gogreen
« Reply #5 on: September 09, 2013 - 07:54:46 AM »
Whats the finish material your using? :smokin: :eek4:
71challenger-millcreek park\71challenger-millcreek
Offline 72cudamaan
« Reply #6 on: September 09, 2013 - 08:37:26 AM »
That's the backing from the linoleum. It may scrape off but I assume you want to use the original hardwood flooring
that is underneath it? That means using a drum sander to get down to the good base wood. Scraping may cause significant
damage if not very careful.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Fern
« Reply #7 on: September 09, 2013 - 05:08:27 PM »
Offline BIGSHCLUNK
« Reply #8 on: September 09, 2013 - 11:14:28 PM »
Another night of linoleum fun. I've pretty much decided to get the crap up and plywood over the existing underlayment. The wife has found some tile she likes  http://www.mannington.com/Residential/Adura/Search.aspx?FilterCollections=0 Looks like I'm going in that direction anyway.
safety warning - if you have a jenn-air style range (this is one with its own exhaust fan). Mine was floor mounted. If its been on for some years, take it out of the housing and clean it. I had to move it and I couldn't believe the amount of greasy crap in the blower cage. I've got it soaking in degreaser now. After I scrapped the junk off it for 20 minute.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Barracudadan
« Reply #9 on: September 10, 2013 - 07:16:04 PM »
X2  :iagree: Some of that old mastic is known to contain Asbestos do you know when it was put down originally? 70`s or earlier could have asbestos  80`s and after not so much? The older the job the better chance it could contain asbestos. What are you replacing the old linoleum with?
Offline MOPAR FANATIC
« Reply #10 on: September 12, 2013 - 02:13:44 PM »
 :popcorn: OL Bigs,how's the flooring coming along? git r done yet?  :popcorn:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline IMNCARN82
  • LeDZeP
« Reply #11 on: September 14, 2013 - 12:05:40 PM »
Ya that stuff is a real PITA!  The worst I've ever had took a wallpaper steamer with a scraper.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
