Author Topic: Inside window door trim?  (Read 1240 times)
Offline EMCD
« on: September 09, 2013 - 10:10:13 AM »
Where can I find the rubber strips that attach to the door plastics that seal on the inside of the cuda doors?
Offline anlauto
Re: Inside window door trim?
« Reply #1 on: September 09, 2013 - 10:21:37 AM »
Do you mean the window fuzzies ? http://www.ebay.com/itm/1970-CUDA-CHALENGER-CONVERTIBLE-WINDOW-FELT-KIT-BARRACUDA-PLYMOUTH-DODGE-TOP-CAT-/321080074120?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ac1dd1f88&vxp=mtr#ht_8059wt_806  I don't think you can buy just the inside ones, but if you buy some make sure you buy TopCat brand :2thumbs:
Offline EMCD
« Reply #2 on: September 09, 2013 - 03:07:18 PM »
Cool. Any vendors on our site sell them?
Offline rattlesnake
  • Rattlesnake
« Reply #3 on: September 15, 2013 - 09:14:48 AM »
I believe I got these from DMT, I can check to make sure, but be aware I purchased a set that did not mount correctly so I junked them and bought some others that mounted the same as factory. And that is correct you will have to buy the entire set.These are the only ones I have found that mount just like the originals. The others require some modifying that is substandard at best.
keep honking I'm reloading
Offline EMCD
« Reply #4 on: September 15, 2013 - 10:45:59 AM »
Thanks. Dave hooked me up on the inners. I bought some more part to finish off the Cuda. I'm hoping it will be completed next week. As long as the flooding stops here in Colorado.
Offline rattlesnake
  • Rattlesnake
« Reply #5 on: September 15, 2013 - 03:21:28 PM »
Man, you guys can't catch a break. Between forest fires and floods. I hope your luck gets better for sure
