Author Topic: wiper blade refill source  (Read 1211 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: September 09, 2013 - 12:13:28 PM »
Hello All,
Where is a reliable source for wiper blade refills in both 15" and 16"...
I have googled 16" and have gotten some ANCO and Trico hits, but there are a wide selection of possibilities... Anyone recently purchased any refills and have the part number?
Cheers,
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Offline anlauto
Re: wiper blade refill source
« Reply #1 on: September 09, 2013 - 12:41:07 PM »
If you're just looking for a dull silver metal blade like the originals, then NAPA has a line of "Classic" blades, that's all I've been using lately since the price of the correct Trico turtle backs has gone crazy. :2cents:
« Last Edit: September 09, 2013 - 12:45:40 PM by anlauto »
  • Charger Power!!
« Reply #2 on: September 09, 2013 - 07:00:25 PM »
Hey Alan...
I went ahead and used the "wrong" blades YearOne sent Hoss. Since they were 16", I just replaced the actual rubber insert. Now, if you could, please, I need the proper routing for the hose and then a shot of the underside of the hood where the hardware is all located. I googled some pictures, but not totally clear. Both parts of the FSM for '71 don't mention the wiper system, which I find weird..... Maybe I missed it.....
Thanks...
Troy
Offline anlauto
« Reply #3 on: September 09, 2013 - 08:08:39 PM »
I'll take a look through the photos I have on my computer, otherwise I would need to get the car out of storage to get the pictures you require.
  • Charger Power!!
« Reply #4 on: September 09, 2013 - 08:24:36 PM »
I see there are two spades on the washer motor. Where does the ground go to and which spade?
Thanks in a multitude of levels...........  :bigsmile:
  • Charger Power!!
« Reply #5 on: September 09, 2013 - 08:26:21 PM »
No No No........ don't do that Alan........ No need to... I appreciate you even contemplating that...... I think I'm narrowing things down though....
Offline anlauto
« Reply #6 on: September 09, 2013 - 08:33:51 PM »
Goes to the negative one...duh... :roflsmiley:
I think if you look close one should be marked +
  • Charger Power!!
« Reply #7 on: September 09, 2013 - 09:31:26 PM »
I know that goober !!!  :lol: ... I'm taking about the OTHER end of the negative wire. As with the '68-'70 B's, the ground wire went from the motor ground to one of the washer bottle attach screws... I'm asking where, on an E-body with electric motor ( yes, some E's came with manual pumps === surprised I knew that? ).....  :bigsmile:
Offline anlauto
« Reply #8 on: September 09, 2013 - 10:03:07 PM »
One side of the jug has two tabs...it goes to the lower tab. :bananasmi
Offline joelson6
« Reply #9 on: September 09, 2013 - 10:26:53 PM »
uh, what about the wiper blades? ? ? ?  :clueless:
  • Charger Power!!
« Reply #10 on: September 10, 2013 - 07:44:44 AM »
I was given this by a kind gent over on moparts...
http://www.rockauto.com/catalog/raframecatalog.php?catalog=29&partnum=U16R
Hoss, my friend who owns the Challenger went out and bought was YearOne considers the replacement, but it was the complete wiper blade assembly, albeit it was WRONG !!!!!  <<< Blade holder that is, it fit a '70 and earlier arm... So much for Quality Control. But, I went ahead and removed the actual blade and swapped them out with the old torn up ones he had on the car. Worked perfectly.....  :thumbsup:
  • Charger Power!!
« Reply #11 on: September 10, 2013 - 07:46:47 AM »
Wow, and that's exactly where I put it last night.... Sweet !!!! Wish I could get the factory terminal end though ( unless someone reproduces the ground strap/wire )......  It works for now..
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« Reply #13 on: September 19, 2013 - 09:06:56 PM »
I found a couple of vintage anco 16" turtle back refills on ebay for $20.00. I'm hoping they fit. I have a 74 challenger with the stock wiper set up. Havent received them yet so I am crossing my fingers.
