Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
!8 Spline TO Bearing
« previous
next »
Print
Pages: [
1
2
3
Author
Topic: !8 Spline TO Bearing (Read 12496 times)
73EStroker
Sr. Member
on:
September 11, 2013 - 01:41:49 PM »
Anyone know what the / a bearing number is for the 18 spline throwout bearing is for the actual bearing only not the entire TO assembly. Going to install my A855 Passon unit - yes I got it - as soon as I can locate this part.
Logged
Barry (Salmon Arm)
73EStroker
Sr. Member
Re: !8 Spline TO Bearing
Reply #1 on:
September 11, 2013 - 06:31:13 PM »
Got one folks at the local parts store bearing only $34CDN. I would suppose that NAPA or similar have the same part for the benefit of my US and East Canada fellow listers.
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
September 11, 2013 - 06:42:00 PM »
I thought this was a
situation
Logged
ShelbyDogg
Sr. Resident
Reply #3 on:
September 14, 2013 - 11:08:18 AM »
Quote from: Chryco Psycho on September 11, 2013 - 06:42:00 PM
situation
Not anymore! I want to see pics!
Logged
Topcat
C-C.com Expert
Member since 9/16/04
Reply #4 on:
September 14, 2013 - 12:24:43 PM »
Quote from: ShelbyDogg on September 14, 2013 - 11:08:18 AM
Me too! This is big news they're being shipped out.
Logged
ToxicWolf
Resident
Reply #5 on:
September 14, 2013 - 02:12:52 PM »
Cats out of the bag
Logged
Restoration Thread:
http://www.cuda-challenger.com/cc/index.php?topic=93994.0
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
September 14, 2013 - 04:06:40 PM »
Meow !!
73E grabbed #1 .......... now I want one too !!
Logged
Topcat
C-C.com Expert
Reply #7 on:
September 14, 2013 - 11:15:44 PM »
Let's get a better look at this new Passon 5 speed.
http://farm6.static.flickr.com/5149/5659903126_af87c775bd_o.jpg
Logged
67vertman
Sr. Resident
Member since 9-23-2005
Reply #8 on:
September 15, 2013 - 08:08:26 PM »
Yes they are starting to come out. Lets hope Jamie can keep up the production......I am way down on the list, and I was told it would be about six months before I can get one, once they started delivery.
Logged
Current ride - 1970 Barracuda 440-6 4 sp Dana 60 (4:10)
Topcat
C-C.com Expert
Reply #9 on:
September 15, 2013 - 08:55:45 PM »
Sounds like he can only assemble around 10 or so per week?
He'll get back logged on orders quick if that's the case.
I've never seen him post here.
Such a huge database he could tap into here.
E body owners probably spend on average the most on any 70's Mopar musclecar restorations.
Logged
73EStroker
Sr. Member
Reply #10 on:
September 15, 2013 - 10:31:10 PM »
I will post pictures when I get back next weekend to my home. The gearbox is in. Clearances are like stock and you get a new speedo cable that comes out towards the right side and curls beneath the tranny then follows the stock route back to the guage cluster. Not much to say if one has installed a hemi A833 then this is the same. It literally fell in and I emailed Jaimie and told him if the car had been standing on its nose then gravity would have installed it. I went easy and gently pulled the tranny in a little at a time by turning one of the four mounting bolts then moving to the next. Right now Jaimie has not caught up with the shifter rods so I wait for them and the shifter before I can drive it. I did start it up and this thing is smoother than you can imagine while running in neutral. Absolutely no vibration or grinding or rattling. I cannot wait to run this thing. I would highly recommend that anyone that gets this unit finds a hoist and tranny jack to install it. It is worth a lot of money and makes the install so much more comforting and easy doing it that way.
More later.
Logged
Barry (Salmon Arm)
ShelbyDogg
Sr. Resident
Reply #11 on:
September 22, 2013 - 05:17:47 PM »
So I get an update:
"Here are the pictures. Last one of installed unit will hve to come later. Will
have to take as low resolution as I cannot get it below 310kb"
But don't see it. Did you delete your post?
Logged
73EStroker
Sr. Member
Reply #12 on:
September 23, 2013 - 02:21:05 PM »
I deleted the post as the pictures all came out wrong resolution. Will redo this tonight and post them. Cant remember on the Apple IPhoto how to resize damn pics so will do on Paint on Windows.
Logged
Barry (Salmon Arm)
73EStroker
Sr. Member
Reply #13 on:
September 23, 2013 - 02:36:03 PM »
Here we go. Hope they are ok quality wise
Logged
Barry (Salmon Arm)
ShelbyDogg
Sr. Resident
Reply #14 on:
September 23, 2013 - 07:28:30 PM »
I think that I can modify a stock shifter to work with that but the plates they give you to mount the shift rods to the shift forks have too much distance between the holes, to keep the shifter from hitting the stops before being all the way in gear.
Is the supplied shifter stock looking?
Logged
Print
Pages: [
1
2
3
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
